I think, and don't take this the wrong way, that the 4-stroke is for the less intense, the ubridled and un-predictable nature of the 2-stroke is meant for those who crave balls out power. I have ridden the best that both worlds have to offer, and I contend that 4-strokes will never equal the snap and responsiveness of a 2-stroke.
It is a good article. It is just a shame that they are outlawing the production of new 2-strokes. There is nothing like the thrill of getting on a fast 2-stroke. The acceleration is just amazing.
I cant post an opinion on this one because Ive never riden a 2 stroke. Everyone I know has a 4 stroke. I just dont think they should outlaw the 2 stroke. Makes me wonder...are they going to be doing that to bikes too. It wouldnt make sense to have 2 stoke bikes and not quads.
The whole reason for banning the two stoke is the pollution issue, what I don't understand is that many two stroke outboards use a direct fuel injection, this way there is no unburnt fuel being pushed out of the exhaust port, this not only increases efficiency, it decreases pollutants. So why don't manufacturers just use this design instead of getting rid of them all together? Direct injected two strokes are lighter, faster, more efficient and less polluting than 4-strokes.
Does is cost more for the manufacturer to make the quad that way? Not that it should matter if they wanna keep selling them.
I'm sure it does, but I can't imagine that a direct injected 2-stroke would be any more expensive than a fuel injected 4-stroke. But I could be wrong.
Outboards are mostly 4-strokes now, but before they switched some used the direct injection to help with efficiency and emissions. I am just wondering why that didn't spread to the ATV/Cycle world, seemed like a good idea, but maybe they were problematic or something.
Because oil is put in the combustion chamber, two stroke engines smoke a lot, which is the reason for the imminent ban on them
If you know how to Mix Properly they dont Smoke much....The Leaner the Meaner:cool:
Although the rebuild is not terribly expensive, it must be done periodically to avoid rebuilding the entire engine.
:aargh: Again,,If you know how to Run your ride you wont have an Issure....Ive Seen 2 Smokes on thier Stock Piston Running Strong after 20 yrs....:yes:
In order to tap into the power of a two stroke engine, you have to keep the throttle close to wide open to stay in the power band.
Oh my God!!!! This article is Clearly an Attack on the 2 Strokes...Im at a loss for words right now...
"In order to tap into the power of a two stroke engine, you have to keep the throttle close to wide open to stay in the power band."
WTF I don't think they would say that again after riding a big bore 2-stroke like a CR500 or KX500.
2 Stroke vs. 4 Stroke
Disadvantages of the Two-stroke
You can now see that two-stroke engines have two important advantages over four-stroke engines: They are simpler and lighter, and they produce about twice as much power. So why do cars and trucks use four-stroke engines? There are four main reasons:
Two-stroke engines don't last nearly as long as four-stroke engines. The lack of a dedicated lubrication system means that the parts of a two-stroke engine wear a lot faster.
Two-stroke oil is expensive, and you need about 4 ounces of it per gallon of gas. You would burn about a gallon of oil every 1,000 miles if you used a two-stroke engine in a car.
Two-stroke engines do not use fuel efficiently, so you would get fewer miles per gallon.
Two-stroke engines produce a lot of pollution -- so much, in fact, that it is likely that you won't see them around too much longer. In fact they are being banned in 2006. The pollution comes from two sources. The first is the combustion of the oil. The oil makes all two-stroke engines smoky to some extent, and a badly worn two-stroke engine can emit huge clouds of oily smoke.
Each time a new charge of air/fuel is loaded into the combustion chamber, part of it leaks out through the exhaust port. That's why you see a sheen of oil around any two-stroke motor. The leaking hydrocarbons from the fresh fuel combined with the leaking oil is a real mess for the environment.
These disadvantages mean that two-stroke engines are used only in applications where the motor is not used very often and a fantastic power-to-weight ratio is important.
Engine Comparisons
I have not riden a 2 stoke since 87. A friend had a 250 QuadRacer. WOW that was a blast. If you ever get a chance to ride a 2 stroke , do so! I think the reason they did not try to keep the 2 strokes is because they are to worried about utility sales and not enough about sport quads. Personally I think there should be a quad for everyones needs and what they want. 2 strokes are pushed aside like 5 speeds will be for utility quads. I do not ride sport quads anymore , but the 2 strokes are a rush!! Long live the 2 strokes you guys and gals out there own or own down the road.
The main reason for the change is pollution. 2 stroke engines go way back. Alot of diesel engines used to be 2 stroke. There is a plus side to it. This is the reason that 4 strokes have progressed so much in the last couple of years. The atv manufacturers had to come up with 4 stroke engines that would keep up with the power demands that motocross and other types of racing demanded. This wasn't a recent decision. The first I heard about the 2 stroke issue was around 1999. That's why the thumpers started showing up. Look at it this way. If they phased 2 strokes out and the riders had to start riding the 4 strokes that were around in 1998 the riders would have been really upset at the power loss that they would have seen. Not to mention the weight of the motors back then. So they started making motors like the 400ex, the 660raptors and the 450's. They used existing technologies to base these motors off of. For instance, You'll notice that the new motors have oil tanks on them. The reason for the oil tank is because with an oil tank the motor doesn't have to be as big and the less oil you have in the crankcase the less the crank has to move through. This technology has been around for years. Alot of race motors(v-8 motors) use a dry sump motor for the same reasons. So with less oil in the crankcase the cases don't have to be as big which equals less weight. Remember how big the old 350 motors used to be. That was partly because all of the oil was in the cases. But all this doesn't mean that the 2 strokes are gone forever. There are already people making all of the 2 stroke parts that you'll ever need. I like 2 strokes, but I also like the challenge of making the 4 strokes fast. We are catching up. Look at it like this, Take a banshee motor. A banshee motor fires and makes power 2 times per revolution of the crankshaft. A 4 stroke makes power 1 time for every 2 times the crankshaft makes a complete revolution. That's the reason they put out so much power. Now they have people making cases to put a 3rd cylinder on banshees. The 2 strokes are long from being extinct.
The leaner the meaner yea, but remember if u run to lean u will cause motor wear faster then normal because of more friction ,or if u run to rich u will make the motor run hot because u would be burning more oil then gas, the gas helps to cool the pistion. BY THIS I MEAN THE OIL TO GAS MIXTURE RATIO'S!!
Hmmmmm,,,,,,
RICHER and LEANER.
I know these terms can cause some trouble for those who are new to the sport or new to carburetor tuning and they are often used incorrectly. The terms RICHER and LEANER refer to the amount of GASOLINE being delivered to the engine and not the amount of oil. If you’ve done a plug reading at wide open throttle and the plug indicates you are running rich ( dark brown to black ) this is an indication that too much gas is being delivered to the engine and not too much oil. I know there are people that will say "You’re running too rich, try to change your premix ration from 42 parts gas: 1 part oil ( 42:1 ) to 50 parts gas : 1 part oil, that should lean things out a little ". This is in fact increasing the amount of gasoline ( 8 more parts of gas for each part of oil ) and causing the engine to run RICHER rather than leaner. If you remember richer and leaner are referring to the amount of gasoline being delivered this will all make much more sense.
A Plug Chop is the First step in Dialing in your Ride. With proper Jetting, Proper Needle Clip Position, and a properly Set Float.....You can Dial in and run 50:1 without ANY PROBLEMS! Mines been running for 22 yrs With 2 top end rebuilds and 1 Crank Bearing Replacement...
However,,,,I dont Recommend anyone doing that unless they know what they are doing...
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By Atomusthenes
    • By worldmotocentro
      FOR SALE : YAMAHA 300 HP 4 STROKE
      Purchase your choice of quality outboard engines at affordable prices
      New & Used Outboard Motors (2-Stroke and 4-Stroke)
      Brands: Yamaha, Honda, Evinrude E-TEC, Mercury, Suzuki, Tohatsu Jet Skis, Sailboats, Powerboats, Watercraft, and Snowmobiles
      For Inquiries, Contact Us:
      Whatsapp Text: +1 (217) 460-7668
      Email: [email protected]
      Brand: Yamaha Motor, Yamaha Motor
      Weight: 229 kg (505 lbs)
      Manufacturer Item Number: Lf300xca
      Inbox if you're interested
      Contact for Purchase.
      Whatsapp Chat Number: +1 (217) 460-7668
      Unleash the ultimate performance on the water with Yamaha’s 300 HP 4-Stroke Outboard – built for speed, strength, and reliability.
      ✅ Unmatched Power: Smooth, responsive acceleration with 300 horsepower at your command.
      ✅ Fuel Efficiency: Advanced 4-stroke technology gives you more time on the water, less at the pump.
      ✅ Quiet & Smooth Ride: Yamaha’s cutting-edge engineering delivers powerful performance without the noise.
      ✅ Built to Last: Rugged design and legendary Yamaha reliability keep you running season after season.
      ✅ Smart Technology: Integrated digital controls and monitoring for precision handling.
      Whether you’re chasing fish offshore or enjoying high-speed runs, the Yamaha 300 HP 4-Stroke is engineered to take you further, faster, and stronger.
      ⚓ Yamaha – Reliability Starts Here.
      📞 Contact us today for pricing, availability, and special promotions!
      +12138024396
    • By 97kingquad
