2003 ltz400 driving me crazy!!!!!
OK long story short....bike was running great no problems and i was back in the woods one day and it stalled .It wouldnt restart ,kept wanting to but it wouldnt.I towed it home.It sat in garage for a week ,i would try starting it every couple days ,it wouldnt.Then one day it fires right up.I kept starting it once a week with no problems.Then after a month same thing just wouldnt start.I but a battery tender on it for a day, then it fired right up,problem fixed i thought.So i turned it off and tried again and it just turns......IM going crazy over this thing,the battery is good.....
Any help would be super
ok ,its such a pain just getting to the spark plug on this thing,u gotta dissasemble everything.But i will do so tomorrow and check for spark and fuel........its just weird how sometimes it fires up normal and other times it wont at all ....depends on what day i go out there to start it.
Not necessarily, it could just be a bad kill or key switch or a loose wire somewhere. You need to find the point at which the power is lost. Trace the power from the battery to the coil and make sure to hit every point in between. Wherever power is lost lies your problem. There are several tests you can do on some of your ignition components using a multimeter. If you don't have a repair manual, get one, it will tell you how to do these tests and also is full of other important info.
well i have the bike torn down and i am not getting any spark.The coil isnt getting power so i thought it might be the cdi so i ordered one and they sent me one for a 2006....it didnt fit.Soooooo i really dont know what to do now,from what ive been reading,they dont usually go bad.
The don't go bad often, that is for sure. The thing that I am having a problem with is that your manual says if you have not power to the coil, then the CDI is the problem. There are many places that you could be losing voltage. If you are losing power before the CDI, then the coil also won't have any power. I would take a multimeter, start at the battery and start tracing power throught the ignition systems at each junction point. Pay close attention, looking for damaged wires and loose connections. Make sure to chech any switches, kill switch, key switch, clutch safety switch. Good luck.
  • 8 months later...
true true!!!! i read this post all the way through to make sure!!! DirtDemon is right on! i have the same bike! it had sat all last winter with only a few short start/runs! batt was on very low chrage!!!! plenty of voltage to crank the engine but not enough to fire up your CDI box, which in turn saturates your coil, so if no CDI no spark! i have an aftermarket CDI on my bike and i can't imagine it's any different with that! when i jumped my bike with a friends BRAND NEW 400ex the bike cranked the same but fired right up! i'm into building cars too and an msd ignition box for an engine works the same way!!! If it doesn't have at least 12 volts it will not activate! it kinda threw me for a little loop at first too because it did not crank as if the battery was dead and yet i had no spark. but as i said as soon as i jumped the bike it fired right up!!! i ran the bike pretty hard that weekend after a good little warm up period and haven't had a problem since!!! luckly the batt recharged from the stator! but in your case your batt my be to far gone? if anything put your meter on the battery while cranking and see what kind of voltage you have!
sorry for the long post but sounds very familiar!
  • 12 years later...
Hey guys I have a problem with my 2005 Ltz 400 , everything was going good until one day until it stalled out and the bike turns over but won’t start up , I cleaned the carburetor also replaced the starter clutch, and also the stator and it still won’t crank up I had bump started it and the bike had stayed on for a while then later on that day it stalled again and won’t turn back on
You should do a tune up first, clean and gap the spark-plug or replace it, clean the air-filter, check and/or adjust the valves, check and vacuum hoses for leaks, check the fuel supply getting to the carb is adequate by undoing the carb drain screw and checking the fuel keeps flowing even after the bowl has emptied, start and warm the engine up and adjust the idle mixture and speed as recommended in the service manual.
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
    • By p5200
      I'm assuming, it's alright to test the engine after adjusting valves without the rear axle installed? Can someone please verify this? I'm waiting on axle parts and wanting to get that done while waiting. Thanks! 🙂
    • By Werewolf
    • By Scoopeddad
      I have a 1994 big bear and I am starting to have issues starting. I put in a new starter and selnoid as the at stopped starting with the electrical but will still start with the pull cord. Where and what now should I be looking at to check? If I turn key to on and the switch to on then hit the start button, the bike clicks and then nothing. Lights still work but no response to the starter. Stumped now. Any help would be greAt.
