  • Join Today, It's Simple and FREE!
Ajmboy
What oil do you use?
Do you guys buy oil from the atv dealer? What are you using in your quads?
I don't go to the dealer. I just go to the local autopartstore and ask them to get me Valvoline atv oil for 4 strokes http://www.valvoline.com/atv/ They also get me my filter which is made by wix filters. http://wixfilters.com/filterlookup/atv.asp
Just curious what everyone uses...
Share this post
Link to post
Here's the Amsoil synthetic:
AMSOIL Synthetic ATV Oil
Formula 4-Stroke® Power Sports
AMSOIL Synthetic ATV Oil, Formula 4-Stroke® Power Sports Synthetic Motor Oil (AFF), is specially formulated for ATVs, snowmobiles and other power sports applications. Its broad viscosity range and wax-free formulation make it excellent for use in both hot and cold temperature extremes.
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
30-Gallon Drum
55-Gallon Drum
PRODUCT DESCRIPTION
AMSOIL Formula 4-Stroke® Power Sports Synthetic Motor Oil (AFF) is specially formulated for ATVs, snowmobiles and other power sports applications. Its broad viscosity range and wax-free formulation make it excellent for use in both hot and cold temperature extremes. As an SAE 40 weight motor oil, AMSOIL AFF provides outstanding protection for hot operating engines, while its 0W rating and -60°F pour point ensure easy cranking, excellent cold weather starting and quick post-startup protection. Formula 4-Stroke® Power Sports is an extreme temperature lubricant that provides outstanding performance in high performance, recreational or work/utility engines.
Resists Heat and Thermal Breakdown
AMSOIL engineered Formula 4-Stroke® Power Sports to withstand the high temperatures of recreational engines. It effectively resists oxidation and oil vaporization to prevent carbon/varnish formation, control oil consumption and minimize exhaust emissions. AMSOIL AFF controls oil thickening for good fuel economy, and it keeps engines clean for peak operating efficiency.
Excellent For Transmissions
AMSOIL Formula 4-Stroke® Power Sports is wet clutch compatible and contains no friction modifiers, making it ideal for both two- and four-stroke ATV transmissions. The friction modifier free formulation is designed to prevent clutch slippage, delivering maximum torque and power to the wheels – a critical feature for towing or high-horsepower engines.
Superior Wear Protection
AMSOIL AFF is formulated with high levels of anti-wear additives that provide excellent protection for pistons, bearings and gears in transmission containing units, while its shear stable, SAE 40 viscosity delivers a thick lubricating film for an extra margin of protection in hard working engines.
Anti-Foam
Churning occurs in high RPM engines that can cause oil to foam, depleting its lubricating abilities and increasing heat and wear. AMSOIL AFF controls foam, promoting cooler engine operation and reduced wear.
Special Additives
AMSOIL Formula 4-Stroke® Power Sports contains robust dispersant/detergent additives that effectively neutralize the high levels of acids and combustion by-products prone to small engines. And it is anti-rust fortified for superior rust prevention, which is especially important in seasonally or infrequently used power sports equipment.
Applications and Recommendations
AMSOIL Formula 4-Stroke® Power Sports Synthetic Motor Oil is recommended for four-stroke engines and transmissions on two- or four-stroke powered applications. It is an all climate/all season oil that replaces 0W-30, 0W-40, 5W-30, 10W-30 and 10W-40 oils for ATVs, snowmobiles and other power sports equipment. Manufacturers include Polaris®, Honda®, Yamaha®, Bombardier®, Suzuki®, Kawasaki® and Arctic Cat®.
API SL/CF, SJ, SH, SG
JASO MA
Compatibility
AMSOIL Formula 4-Stroke® Power Sports is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives are not recommended for use with AMSOIL motor oils.
Service Life
Follow the equipment manufacturer’s recommended drain intervals.
This link is available to logged in members only. Please login or register to view this link.
Share this post
Link to post
i use mobile 1 synthetic motorcycle oil in almost all my atvs .. it might cost more than alot of the others out there ,but i have been using mobil 1 synthetic in my drag cars for years with great results and less rebuilds on very high horse power motors and thats good in my book ...
Share this post
Link to post
I've always run Amsoil 0-40 and filter. Have had pretty good luck with it. I tried their ATF in the hubs (manual says ATF is ok to use), but it leaked past my seals. So I decided to stick with the Polaris stuff for that.
Share this post
Link to post
I have been using AMSOIL for the last few months in everything from my tracotr to ATV. The ATV shifts smoother and seems to run better....I had never heard of it until a few months ago and a friend of mine started selling it. I am sold....
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
      Common misconception is that you need to return to the dealer for an exact
      oil filter for your ATV.  Aftermarket companies actually make filters for
      the O.E.M. market. Why go to the dealer when you can get the exact filter you
      need at your local auto parts store such as CARQUEST or NAPA. Wix corporation
      makes ATV filters that you'll find in most of your popular autopart stores.
      In most cases, you'll pay allot less!
      WIX is a leader in the filter business.  Check out this
      ATV FILTER CATALOG.  Remember, you can
      right down the filter # and have it cross-referenced at your local autopart
      store if they don't carry WIX, CARQUEST, or NAPA.
      You can also click on the part # for the filter image.
      https://www.autopartsforum.com/topic/23-showmetheparts-catalog/
    • By caperman
      Can anyone tell me a oil I could use in my 99 Honda 450 automatic instead of Honda brand.. I live about 60 miles from the dealer so gets expensive.  Thanks
    • By jbsowers10
      I have a 1997 Polaris sport 400l what type of oil can I use other than the Polaris oil. I have found online that it is a 10w-30 or 10w-40. the other problem its a 2 stroke so do I put 2 stroke oil or just regular oil I need help. thanks to everyone that reads this im new to the atv world
    • By texaskaw
      changing stator in a 94 bayou 400.the oil is milky ,mixed with water.I am replacing water pump seals.how much oil ( if any) should be in this side of engine. there has been ( to me ) a lot of condination from vent tube lately. don't think head gasket is bad it was running ok when it was running. what do you think..
