1990 Suzuki LT 4wd need help running issue
joseph
thanks for advice but i have checked fuel flow even hooked up another tank so it would feed carb by gravity,also i bought a after market carb it does same thing iam not driving the atv its just sitting there in neutarl is there any thing electrical that could cause this? i sure appreceate the help i tried going to the suzuki forum site but after joining couldnt figure out how to ask a question cant even log in anymore its crazy how complicated that site is so i hope you guys can help me i have cleaned tank new fuel shut off new fuel lines new vacume line to fuel pump new coil new spark plug new plug wire new coil rebuilt carb set float
Your spark may be breaking down as the RPM’S come up.  This happened with my Polaris which had a rev limiter on it also.
So @06kfx440 may have a point.
I was pointed in the direction of a faulty rev limiter on one of my bikes through the forum here.
I purchased this spark tester and put it in line with the spark plug. Started and watched the spark break down/fail as I reved the bike.  I removed the rev limiter and my problem was solved.   Worth a shot and cheap enough to try. It’s also a good tool to have.
Having ruled out the fuel system it may be time to start looking in the ignition system.
Rev limiter
bad pick up coil
stator coil problem
regulator
cdi box
4 of the 5 above listed parts can be tested and the repair manual will explain as far as how and what numbers should be shown on the tester during this process.
I attached  a pic of the spark tester.
  • Like 3
On 11/2/2018 at 3:33 PM, joseph said:
my atv will start right up will idle fine soon as i try to throttle up engine dies,i have changed gas,new fuel pump and lines great compression 188 lbs.new coil new spark plug adjusted valves dont know what to do also rebuilt carb,any help wanted
Is that the compression reading before or after adjusting valve  just wondering
  • Ajmboy changed the title to 1990 Suzuki LT 4wd need help running issue
Check the charging system. Sounds crazy I know but every now and then I get a machine that nobody can seem to fix. An over charge condition from the charging system will cause the CDI to shut down. At idle the machine may be showing 14-15 volts at the battery. As soon as you touch the gas the voltage shoots up (due to higher alternator rpm) and the Ignition system quits. The charging system should charge no more than 14.5v at 2500rpm or so. I usually do this as pre check before I actually start working on a machine. Sounds like you did everything else.
I can tell you what the problem is Guaranteed!. So please attempt to try my option out .
Every single Suzuki I have ever owned has done the exact same thing . Suzuki are cold hearted women . PERIOD.
So what you do is start it with the choke on . Leave the choke on for a while. After about 5 or 10 minutes , the engine will start to Rev and Rev and Rev until it's almost redlining. Then and only then take or turn your choke off . If it's a lever that you pull up , you may have to lightly tap it down a hair at a time . Like tap , revs lower but stays running , tap again , lowers Rev  etc. Until it's off and it stays running and idles with no choke or throttle . Then you can take off , shifting and giving it throttle . If the doing the steps does not allow it to idle on its own , adjust your idle screw so it does. Suzuki carbs are ULTRA ULTRA sensitive with this adjustment , so it may not run with a quarter turn left or right , but it will at an Eighth of a turn . So don't give up , it just takes a while , but once you get that idle screw perfect, Don't ever touch it again EVER. Then you only have to deal with the choke. This is the way all Suzukis are engineered to work . Trust me . Although every post on here has good intentions , I guarantee you success . Good luck my brother.
thanks i will try that the thing is it never did that before since i bought it i rebuilt the carb at least 5 or 6 times finally bought a different new carb from a place that could get a aftermarket one it ran great for a year and a half  then it would start this i would work the throttle it would straghten out but now it wont . the one thing i noticed was that neddle with the groves is a 1[8 in longer then in a kit ive even tried different kits all have the shorter needle  iam 79 was a heavy equipment mechanic many years figured i could fix about anything but not this ILL TRY WHAT YOU SAID AND THANKS
this is actually very useful thanks for the information!
Don't worry brother , youre doing just fine ...well get it running ....
Are you saying that the Current needle on the bike is Longer than normal ? If that is the case , I would ask if you NEED to ,meaning every cold start ,   start the bike with or without the choke currently?  If you don't use the choke and it starts  and idles , then dies when throttle is applied , then we need to get it to NEED the choke on cold starts. Once you reply ; we can go through dropping or raising the needle in tandem with your idle and/or air/fuel screw .
Just Fyi , Suzuki chokes are not chokes but Enriching  circuits be it air or fuel.
right now and for a year and half the aftermarket carb was and is on machine,,i do need to chock it to start it starts right up i let it run a few minutes try to rev up it quits if i dont rev it up it probabley idle all day i cant rev it up to check voltage it quites a inline spark checker shows spark i do have a new reglator have to take front fender off to change before this happened i would run it a couple times a week for maybe 5 houres mostly to bring out wood it has a xtra low independent suppension front and back did great on this land i have
Try adding a little choke when you try to rev it up. If it rev's up its fuel starved. The bottom air fuel adjustment is very very touchy.
If you rebuild the carb. use a very small wire or get a welders tip cleaner to check all passages after you blow low pressure air backwards through the passages, spraying a carb cleaner through these ports backwards is also good, be careful not to get any cleaner in your eyes. Backwards means from the carb center back in to the fuel bowl or air inlet areas. Anything in the passage will be blown out and not inwards.
Also try clamping off all the lines going to the carb one at a time. Found mine had been getting a little extra fuel via the vacuum port on the fuel pet cock.  Have also seen a cracked vac line that stayed closed at idle and would open up when more vac was applied (motor rev up a little).
Make sure all your lines going to the carb are in the correct location. Had some line change out and it either didn't run right or not at all. I've taken all the lines off more than one and started from scratch and fixed the problem.
One last thing is most Japanese products don't play well with champion spark plugs. I personally used NGK or Nepondenso plugs. I have had a bunch of problems clear up by just changing the plug out. Even in cars,  Had perfectly good running motor, changed plug/s and ran real bad, put the old plug back in, ran fine. put a new Ngk plug in ran fine, new champ and turd city.
i want to thank every one for there advice i tried all if i hadnt did that before a member shane meguffie was right on checking voltage it was 17 i put on new one 14.4 volts ran ok except carb needs proper adjusting and i will be glad to take all advice you guys sure helped me out. i never could take to a dealer because of cost suzuki  atv parts ar  way over  priced i ran into that on a wheel cyl. suzuki wanted about %50.00 a suzuki truck same wheel cyl. %10.00 at amazon,and the area i live in the dealers are aragent
    • By Flash_fella
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By oxidized_black
