By Flash_fella
By Brantley11
Hey everybody,
Here is where we sit:
New 93 Non Ethanol Gas
New Spark Plug
Bluish white spark
Good Compression
Here are the readings:
By oxidized_black
Please visit the downloads section at https://www.quadcrazy.com/files/
By Gwbarm
