Ah so the end is near! I am not really sure where to put this topic, hopefully this is the correct spot.
As 2018 is coming to a end I can't thank everyone on this forum enough on the support you guys have gave me on my YouTube channel. As I am still a small creator I still love pumping out some quadding videos for everyone to enjoy.
I don't ask you guys much at all so I hope it would be ok for me to ask you guys to hlep me achieve my final goal for my YouTube channel in 2018.
My goal is to reach 400 Subscribers. I currently sit at 378, If you could find the time to make a few clicks and give me a subscription I would really appreciate it! (you only need a Gmail account)
Channel: https://bit.ly/2Ae78Su
Happy Holidays and safe riding!
  • Like 3
2 hours ago, michael absher said:
gmail, whats gmail?
  Sorry bro, I don't have a gmail, otherwise I would.  Hopefully enough will chime in here to help you out though.
its a email account, you can also use a YouTube account to subscribe! :)
16 minutes ago, davefrombc said:
I  made it 388  Dan
Thanks so much man! y'all the best quadding community out there!
14 minutes ago, Frank Angerano said:
Me too. 👍 great channel ! 2019 let’s hope you have double !
Thats the plan! Thank you!
On 12/25/2018 at 12:00 AM, johniii said:
Good stuff.78bb0c959f88dcf37ebde9ee9eab0d09.jpg4b3f0f9901fed179c2bfacff05f3b5d7.jpg
Sent from my SM-G965U using Tapatalk
Haha HELL ya! Thanks guys!
On 12/25/2018 at 4:48 AM, Frank Angerano said:
That is amazing! Off to a great start for the 2019! Merry Xmas #Quadcrazy
Cant wait to see what 2019 holds for all of us!
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By HoldenBoy
      Hi all,
    • By HHurks
      Hi to all
      Newbie here. Not new to ATVs. Look forward to learning a few new things and hope to maybe help some too.
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
