The End is Near
By Rockbottom
By HoldenBoy
By Ajmboy
QUADCRAZY has been around over 10 years now and there a lot of members that have come and gone. We had a PM message going so I decided to start a topic. If I miss anyone, please post. Anyone can post, even if you are not an old member, but please keep to the theme of updating us on what you are doing now, what's new, where you are hanging these days, etc.
Some of the old timers: @SunLrider @CK1999_400ex @trailblazer_02 @hangingon @pete59edsel @fox300exchic @powermaddd400ex @Raptor8 @GREENIE @NEWACRIDER @atvredefined @lawny @jigolbeep @cheriah @Mudflap64 @pony @Lildaisygrl18 @Tagels @mikeexplorer @Lildaisygrl18 @Jonny450R @yokochrist @DeadAim @Bimmerdog @CRAZYKIWI @KnightHawk @Senator @mellowyellow @DJLime @Desert-Hawk @davefrombc @jeeptuff @kidatvs @kfx450r @hvy_chevy_one @Roody @rappy97 @Gunny @ALLYRATT @PolarisRich @Tim-ANC @jerod400ex @MIKEL5469 @swampcat07 @DirtDemon @quadmaniac @WillyPoP @marioweldinginc @BioWare @Sc0tt @wylde1 @nueymansiyami @oxidized_black @mywifeknowseverythin @BuckBilly @Ajmboy @Stoopidbot1 @DrtyGrlKristin @outlander560 @01 RAPPY 660 @joet82 @wheeler0801 @Sparrows @quadnut20
Sorry if I missed anyone. Looking forward to hearing how everyone is doing. 😎
By HHurks
Hi to all
By middlebrookgt
