Frank there is a vacuum line coming from the oil reservoir going to the airbox then the two vacuum lines that go onto the carburetor they are all clear. Which direction but I want to go with the needle up or down
Edited by Kurt Reiser
Ok the reason I’m asking:
1. I’m wondering if there is a problem with the vacuum where as soon as you hook the air box up the vacuum lines are drawing all the air from the air box starving the air flow into tye carburetor. Why? No clue! Just wondering if that’s what’s going on. May sound stupid but you never know
Try to move the needle on the carburetor and see how that goes.  Make sure you remember where the clip was on the needle before you move it.
  If that’s not the fix then disconnect all hoses going to the air box, reconnect to the carb and try to run the bike and see what happens.
Side note. That clip and spring set up in the carburetor can be tedious. Parts can fly off and never to be found again. Work in an area that will prevent that from happening.
Did you check the carb to see if it  had  both the  air screw  and the fuel  screw? I can't see the  air box being a problem  unless either the  main  duct to  atmospheric air  is severely  restricted or the air filter  plugged.  The amount of air a vent or vacuum line connected to the  box would affect would be absolutely minimal .
When  you  move the  clip on the  slide needle , you  should only try one  notch at a time up  or  down at a time  from the original  setting .
That's why I suspect a  plugged passage or the carb has both an idle air screw like most  carbs , but may also  have a fuel mix screw ..  The ones I see illustrated like the one in the video  I  posted are  not the thumbscrew  type but look  more like a  regular  plug screw ( for want of a better term )
I agree👍  Although....  I moved my needle on my sportsman's carb up two notches...  problem solved.  no more adjustment needed- the bike runs perfect.  Its got to be something big that we are just missing to be causing the bike to just not run....  Are you sure its starving for air and not fuel?  I mean it seems pretty obvious to me that its air...  but I wouldnt just rule out the fuel till you're sure.
Frank I was having problems signing in for some reason I’m very illiterate when it comes to these computers what I said was I don’t think it would be a carburetor problem both carburetors are doing the exact same thing. there is  only one screw on the bottom of the carburetor I’m not quite sure if you asked that question it seems like it’s something very simple because the bike runs great as long as you don’t hook up anything to the back of the carburetor it’s bizarre There are no obstructions in the airbox there are no obstructions in any of the vacuum lines I will check the cam and check the valves check the plug have move the needle up-and-down one groove at a time.Sorry if I sound repetitive I’m just getting so frustrated
If its worth it to you, I would love to take a look at your bike if you brought it down to me-  I cant come to you because I'm under-aged and cant drive yet😣
im in christiansburg VA.  If you are interested, massage me privately and I can send you my address.
but if you want to figure this thing out on your own, I totally understand!  I'm just really curios as to what the issue turns out to be.
  • 6 years later...
Ok, before someone gets mad at me for resurrecting an old thread, this diagnosis information is valuable and still very valid.
I have a 1995 Polaris Magnum 425 4X4 and I am having the EXACT same problem.
Did you ever figure out the problem and if so, what was it?
My carb has been rebuilt, new fuel pump, new fuel lines, new OEM Polaris air filter, new OEM fuel filter, new recommended spark plug, fresh ethanol free gas.
With airbox cover on it bogs down, with airbox cover off it runs way better but will not go over 40 mph, but at full throttle with the cover off I get that more powerful high rpm sound you get when you goose it.  with cover on it bogs and struggles.
It seems like something is restricting airflow but it is not.
Could the carb just be needing to be adjusted to allow more air?
When it is warm with airbox cover off it and in neutral when I rev it the engine quickly returns to idle like it should if it the carb is tuned.  But maybe there is room there for better tuning?
Any help would be appreciated.
Jeff
  • 3 months later...
I've been working on a customers 2004 with the same issue and found the intake rubber boot is leaking air causing the issue. Spray contact cleaner around the boot while it's running and see if it stalls. Alot of 400 and 500 machines seem to be having the same issue all of a sudden.
If it's getting too much fuel, a leaking intake boot would help the situation, not make it worse.  I would verify it is indeed getting too much fuel as suggested by the tech.  Hook everything up and letting it stall.  Immediately pull a spark plug and see if it's wet.
Ok update on the running issues. What's causing this problem is the needle jet gets worn oblong from wear of the needle going up and down and the forward and back pulse of the engine. I removed the needle jet and put a scratch awl up through the bottom and shined a flashlight underneath and you can see the oblong wear of the needle jet. On my customers machine the needle jet is obsolete so I shimmed the needle down with a washer half the thickness of the original and dropped the main 2 sizes and it now runs perfectly. The plastic washer is the oem and the metal washer is the new replacement.
    • By Elk
      2002 Polaris Magnum 325
    • By mehim
    • By vaneleus
      Hello there
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
