1995 Polaris magnum 425 will not run with airbox hooked up
By Gwbarm
By Gwbarm
I Ran across this video today comparing an aftermarket to OEM Carb on Suzuki Vinson, thought it might generate some interest, it is quite long but informative.
By semicolon
By NZrider
By jatho
