Dra O
1999 suzuki king quad fuel pump/petcock/carb advice
Its in the right way and it looks primed to me. I would try the air restriction method and see if it revs higher.  Just trying to rule out any kind of rev limiter that might not be working if your atv has one. Also try making an adjustment on the air/fuel screw.
Edited by Frank Angerano
Share this post
Link to post
At least you saw it   driven  out in the right direction ...Up toward the top  of the carb from the bottom. I hope that's where the problem  is .... one or more of those tiny drilled holes plugged.
Share this post
Link to post
No holes plugged - and it came out fairly easily - wouldn't have known about the status of the holes until it was inspected - very positive.
I cleaned it with carb cleaner, ran small wires through the holes, blew through top / bottom while holding opposite end, then cleaned it again, dried with compressed air and re-inserted
regarding frank's idea about the air restriction method:
1) "Put the choke at half way after its warmed up" - you mean the screw-in apparatus that's external to the carb - turn it one way, engine revs, turn it other way, engine slows down?  I tried this before - turned it way up so that it idled high - then pressed throttle but it still bogged.   i also turned I down but this didn't work either.  i'll try it again.
2) "OR try and cover of the intake on the carburetor halfway with your hand and see how it throttles up. If it revs with a little restriction of air then its obvious that there is a fuel shortage happening someplace within. By creating an air restriction allows for a better fuel mix and that allows the engine to rev" - do you mean leaving the plastic boot piece off between the air box and carb, then partially covering that side of the carb while starting the machine?  nothing's gonna jump out and bite or burn my fingers?  I mean, I aint' a wuss or anything, I just like having all of my digits :-]
Share this post
Link to post
Hahaha no nothing is going to jump out and bite you.
 Not the idle setting. The idle screw that your referencing with the black cable is only to be used to adjust the idle on the atv when everything is all said and done.
What i am referring to is your choke. Thats located either on the handlebars or on the side of the carburetor.  Its used when the engine is cold you turn the choke on and start your atv.  Then you push the choke back to the normal position when the atv is warmed up.
So what I'm asking you to try is get the atv started and warmed up, then put the choke on halfway and see if when you press the throttle it still bogs down.
Or the second method is to take the rear boot off the back of the carburetor so you can get your hand in there.  While the engine is already running take two fingers and cover the intake halfway.  Press the throttle and see if it revs up without that hesitation. If it does work then you know you are having a fuel delivery problem internally.
Lastly the air fuel mixture screw may need to be adjusted. As i mentioned before if you can make a small screwdriver that can fit into and under the carburetor so you can adjust while the engine is running is the best way to get optimal air/fuel mixture adjustment. The higher the engine revs the better its mixing as you adjust. Once that is done all you wouod need to do is lower the idle upon completion of that air/fuel mixture screw.
Share this post
Link to post
are you talking about the lever in the 1st pic?  i'd no idea there was a choke on this machine - I've never touched that lever - this could be the entire issue, no?
and pic #2 is the method you're talking about once it's all nestled back down in and hoses/lines hooked up?
now that this idiot knows about the choke switch, i'm thinking of going back to 2 5/8 on the air/gas screw
*** plan is this: put it back in once again, hook everything back up, start it, ADJUST FREAKIN CHOKE SWITCH and see if doesn't bog down
if it bogs down, remove rear boot, cover air intake side of carb w/ fingers, rev it up and see if bogs down
Share this post
Link to post
I think that  red button above the  start  button is the choke,  and it  looks to  be on full choke to me . Does that  red button slide  back and forth ? . It looks like an  arrow indicator to the right of it  and  it is  fully to the left.. If that is the case , that is  most likely  your problem.  Start  the  bike  with  choke  button tro the  left ,,  reduce choke as needed as  it warms up  and do  all  your  fine adjusting  on a warm  motor / choke fully  off..... slid to the  right .
The button you're  pointing to  might be  a brake lock  button .  You  squeeze the brake handle  and press that button  down to  lock  if it  is .
Edited by davefrombc
Share this post
Link to post
That lever your pointing to is the choke.  Forward is on and back is off.  Is it possible you had it on the whole time?
As far as fingers over the rear of the carburetor yes thats what i mean but only covering half of the opening.
But check the choke first before you do anything.  This could be your problem straight away the whole time.
Share this post
Link to post
the red button is the "off/run" switch - the switch my finger is pointing to is the choke.
I think the issue has been solved, ladies - I got it to yard and started it up - it did bog down a bit but I fiddled w/ the choke and whatever happened, happened.  but that's what scares me a bit - all I did was move the choke up and down - it's in exactly the same place - maybe the carb end of the choke cable had been stuck?  trying to screw that outer plastic piece in was (verbal lubrication x10).
Frank, I removed air filter and plugged the air hole w/ 2-3 fingers while running - it shut down - couldn't breathe.
No bogging down, idles decently well - drove it through 3rd gear w/out issues.  let it set for 20 min, started it, let it warm up, no bogging down.
air/fuel pin is back to almost 2 5/8 (factory).  still hesitant to put her clothes back on but her dress was washed - she'll look pretty soon.
pic #1: underside of rear muffler - smokes a good bit here, too - does this piece having holes affect on the performance?  oughta be fun cutting through that rust
pic #2: choke switch: arrow points downward - if pulling it downward, it's going to advance the mechanism inside carb - the rod within the spring will advance into the "hole" in carb and plug this up, i'm assuming creating some type of seal; pushing the choke switch forward will retract the rod within the spring and open some important area w/in carb
pic #3: muffler pipe - this area was smoking a good bit after the brief ride - haven't removed shroud - wouldn't surprise me if it has a hole
Share this post
Link to post
Lol simple choke, thats great. Awesome news on that.  The smoke that you see is it a pressurized type smoke like you can feel an exhaust leak or an oil burning on a hot exhaust type of smoke.  Reason is a lot of the time the caps that cover the valve adjustment stems will  sometimes leak over time or the valve cover gaskets.
If its an exhaust leak you will feel it or hear it as well.
Share this post
Link to post
Moving the choke lever in the direction of the arrow is "enrichening" the mix, moving it forward/away from you is the normal, run position.
Share this post
Link to post
yes, fantastic news - and a great Christmas present from all who pitched in.  great community here.  I just wish there was a place to donate cash - and I mean that - experts should be PAID for their input.  this group has likely saved me at LEAST $1000 - time, labor, diagnosing, parts, etc. - I am thankful.  and i'll likely be back for more in the future.
Share this post
Link to post
Your  last picture  took  all the guess work  out of identifying the  choke , brake  hold  and  kill switch. . Glad  you  found the problem and it was as simple  as the choke being on all the time .  You'll likely  find you  need to  do  a  little  more tweaking for  max performance and ending any sign  of stumbling ,  but you're  well  on the way  now..   Happy  Quadding , and   have a  Very Merry Christmas.
Share this post
Link to post
Haaa!  I hope she does!  Will post video if youngest child can get video from phone to laptop.
And I may have another "project" soon (I officially have "the bug"... scary thought, I know).  A patient of mine has what he thinks is an older arctic cat - maybe early 2000 model - it's outside his home - not ridden in years - gotta inspect, get specs and see what parts are available first.
This whole process was very thorough - someone else can see exactly what we've done, step by step - try this, don't try that - and it's recorded here with pictures - it's BOUND to help someone having similar issues.
Thank you all again - you guys ROCK!
Share this post
Link to post
took the KQ out for a brief spin - runs really good in this warmer weather.  got home - checked air filter just for kicks - perfect - bright yellow and dry - removed filter out and noticed water in bottom of air box.  not a lot and it didn't get the filter wet.  found drain plug, let it drain, recapped and good to go.  how the hell did water get into the sealed airbox?  I rode it near/around our lake but didn't submerge the machine (i'm not that brave) - at most I rode across 1/4 of water for about 20 feet.  the machine has been under my house in a constant 72 degree, dry environment since last summer.
lastly - any specific brands of solenoids you all like?  RM Stator's looks good and has a 2 year warranty - but I thought stens made one at one time - I cannot find stens online.
Before putting plastics back on (always enjoyable, like getting carb out) I replaced original solenoid with new one off amazon (<$10) - put ALL the plastics back on and it lasted all of 2-3 months until the ol' clickety click click click - bottom of amazon solenoid had rust on it, so i'm imagining rust on internal magnet - tapped it good w/ hammer but couldn't get it to loosen up.  Took plastics back off, replaced with original solenoid and it's going good (at 20 years old). not gonna replace solenoid until have a reputable one - and I may put a light film of grease or permaseal around the joints to keep water out.
thoughts?
Share this post
Link to post
Thats some good news.
RM stator has good products, so i would go that route.
As far as water in the box i find it odd other then that ride you took so maybe a crack in the box? Something has to be kicking up into the box.
 I would dry the box out and hit the bike with a hose and check it.  If not then find some puddles and take a ride and keep checking. Process of elimination I would think is whats going to get to the bottom of this.
Are you sure its water and not any other fluid?
Share this post
Link to post
yep - the seam at end of forceps goes all along the internal joint - I can push the box toward the rear and see the gap widening just a hair.  don't see any other visible joint spaces or fluid/moisture.  should be able to take air box out without touching carb.
gonna hit it with a hose this weekend or next to make sure that's it - but I don't have any doubts.  weird how I just wanted to check the filter and found this surprise
makes me want to leave cap off end to let water flow but don't want any critters in airbox and it may affect performance
so, silicone along outside joint after letting it dry for 48-72 hours?  I wouldn't think it'd be an issue putting it on inside, as well
re: solenoid - I agree - they're $30 but will likely last a lot longer.  putting grease/permaseal on outside joints to prevent moisture won't hurt, will it?
and yessir, it was water - no gas smell - no greasy residue
Share this post
Link to post
  • Similar Topics
    • By jimsvtx
      I'm working on my brothers' 2002 Suzuki Vinson 500 . It sat for a few years before I got into it. I'm concentrating on the carb - I replaced orings, needle, etc. and soaked jets, bowl and anything that I could get off the carb that the solution wouldn't eat. I also removed the tank and flushed it with hot water - it's clean. The gas cap innards rusted away and the tank had a lot of rust and water in it before I cleaned it. I replaced the gas cap and installed a new fuel valve because the screens were broken in the old one. The bike will run but spits and sputters and backfires. If you "open it up" it falls on its face and stalls - but starts right up. Here is a link to an exploded view of the carb: Ohio Honda Yamaha Motorcycle ATV Dealer - J & J Motors - Kawasaki Suzuki Scooter Utility vehicle, parts, accessories, apparel
      Can anyone point me in the direction of the problem? It may still be a "clean carb parts issue" . My problem is that the parts list doesn't identify the parts to a degree that I understand. If you said" look at the pilot jet", I'm not sure which jet that would be....See what I mean? It'll run very good if I remove the air filter and cover the opening with my hand and part my fingers a little for the air to get in. Any help is greatly appreciated.
      Thanks in advance, Jim
    • By JacobSlabach
      got 7 atvs off CL recently for a good price.  one of which is a yamaha warrior.  anyone know where the vin is printed on this bike?  Haha good place to start as I do not know year or size yet.  The former owner says needs exhaust ans and clutch work.  he said it ran fine until the clutch cable broke and then I couldn't get the new cable adjusted right and it would grind gears.  things I see:  clutch cable locked up again, no brakes, carb leaking (green with algae around the bowl and has gelled gas stalagtights on it), aftermarket exhaust melted the airbox so I need something different and a new air box.  I would like the use the current exhaust if I can but I have a feeling its a redneck fix as it looks like there is an ace bandage holding it to the exhaust pipe (its an aftermarket slip-on exhaust), so I'm not sure about that- lets get the bike running first.  also, battery (looks brand new, what a shame) is dead, 0 volts.  Otherwise, bike looks to have not been wrecked, and plastics are ok (it sat outside under a 'tarp' for 3+ years since it was run last).  any tips and advise on where to start first would be awesome as this is my first clutched bike (manual).
      the clutch is my main concern- I've never rode a clutched bike so I dont even know what its supposed to feel like.  lol I'm spoiled on my automatic polaris
    • By JacobSlabach
      got that 220 I'm 'servicing'..........  well it turned into a guts and oil job....  I cleaned the carb and it wont idle cold, but idles too fast when warm.  also misfires and burns rich cold (white smoke out of the exhaust)  I'm going to order a new carb since the old one is leaking and beat up (some one was tinkering)  I'm wondering about the valve clearance and timing...?  Maybe a factor?   What should the clearance be on the valves?  How should I check the timing on this bike?  (this is a mid 90s bayou 220 2x4)
    • By JacobSlabach
      recently picked up some project bikes off CL for cheap.  got a honda fourtrax (the ancient 4x4 kind with the straight axle in the front as well as the rear and a back-up kick-start)  plastics are crap, but my goal is to get running like a champ and patch the plastics up and sell to one of my many friends that want a reliable 4x4 for dirt cheap and doesnt care what it looks like.
      so the former owner says it needs carb rebuilt, but its sat for 3+ years since so who knows.  things I see:  carb is missing (he gave me a box of parts along with the bike), engine turns over and feels good with kick-start, brakes need work, battery missing (That always puts me off, cause then I know most likely someone's been tampering with the electrical.
  • Similar Tagged Content
    • By dp19
      Hi, I'm a newbie on here.  I just got a 2007 Suzuki KingQuad LT-A450X.  Are there any specific issues to look for on this model?  Any specific maintenance to do other than the usual oil and filter changes?
    • By Jack Briggs
      Just bought 06 KingQuad 700 and first ride out hit a mud hole, not to deep and it shut off and would not start.
      Got it home and found the spark plug hole was full of mud and water. Went and bout a new spark plug and began cleaning it out. Put a deep socket in there and it wouldn’t grab. Took a pic with my flash and this is what I see. Any suggestions? And what is it??
      previous owner said it had a new coil so that’s why I decided to change out the spark plug, also ordered new coil should be here by the weekend.
    • By davefrombc
      1987-1998 Suzuki Quad Runner/King Quad 250/300 Service and Repair Manual
    • By davefrombc
      View File 1987-1998 Suzuki Quad Runner/King Quad 250/300 Service Manual
      Submitter davefrombc Submitted 01/28/2017 Category Suzuki ATV
    • By Dwight Williams
      Ok, so I bought this scream of a deal the other day - a 94 King Quad 300 for $40.00.  It's been sitting outside with no carburetor on it for about a year.  Its rusty, missing some parts, wiring is all cut up and spliced etc.  No seat, no racks but the plastic is all there minus the headlight housing.  Anyway, who can pass up a $40.00 quad right?  I get it home and looked at the sight glass for oil level, it's about 1/2 oil and 1/2 water.  I drain it, refill it and turn the motor by hand (recoil starter is missing) and it turns over just fine.  I worked on the wiring for about an hour and got it to turn over with the electric starter and got enough of it sorted out to get a spark.  Did a quick compression test, 70 lbs.  Wet test bumped it up to 90.  Ok, so rings and cylinder washed out with water for a year, not too surprised.  I thought 'what the hell' and sprayed some starting fluid in it and it ran for about 2 seconds - enough to show  it's got life.  Since then the compression has gotten worse, I can't get enough pressure to activate the carb diaphragm, therefore no fuel pump either.  The compression is now around 60.
        Anyway, my question is....is it worth it to try to get this thing going?  I tore the top end down today and the cam and one of the rockers is pretty worn.  I figured a top end job would be about $100 or so, depending on the condition of the cylinder but I'll probably have to put a cam and rockers in it as well.  Doing some research on ebay I figure I'll have to spend about $500-$700 to make the whole machine right again.  Much less just to make it run and use as-is but I won't really like it until it's right.  I don't mind doing the work, I actually enjoy it but I'm concerned about what all that water did to the rest of the internals, I can't really test it all out until I can make it run.
      I know it's a basket case but I'm not into it much at all, even if I do the top end and find something else wrong I'm still not out much.  I'm leaning toward ordering the top end parts and going from there unless you can convince me otherwise - any way to check the rest of the internals without tearing it down?  I plan on flushing the oil cooler before I do another oil change, I've drained it twice now and it gets milky almost immediately just turning the starter - I suspect the oil cooler is polluted badly.
      I'll get some pictures today if anyone want to see them.
      thanks!
