By mga
So, i go to change the oil in my 2k Y 400 BB and, without reading what types of oil to use, i just put in 10w-40 motor oil.....then i decided to read exactly what type of oil i should be using. Apparently, the ATV oil is designed to also work with the clutch..lol...which is probably why i was having a few issues going into the gears, or, maybe losing 1st gear going down a hill. Ok, now that i got educated i bought like 6 quarts of the "special" oil required.
Now, my second issue is it was hard to start for some reason. Usually it fires right up. So, once started i brought it up to the garage and removed the seat, thinking maybe the battery was weak from sitting. Nope...12.5 volts, but.....a mouse decided to build his nest right on top of the battery. I cleaned that all out, but, when i went to start it, the solenoid clicks and the starter just spins. UGH. One thing after another. No wires were chewed thankfully. Just kind weird the starter would do that all of a sudden when i messed with the oil.
Do i need to pull the starter now and check the bendix thing? It spens real nice, it just won't engage. The wrong oil wouldn't do that...would it?
By dvs1961
Just bought a new hisun ,been shopping for a year or more for a sxs best bang for the buck...Are there any lift kits out there for a 2022 Hisun 750 sector ? links thanks
By autocustomizer76
Hey all got a Kawasaki 300 that's seen better days I'm looking to get running. But first, I'm working on a Honda 350 ES and mainly needing where are you all finding quality parts at good prices. Atvs are really hot items around here right now and most of the folks wanting and needing them are not familiar with working on them. I'm looking to find a good resource for information and if it works out well pass this group along to the folks I help to get them in the know how to get the most out of their machines. Thanks in advance.
By blasirl
I have inherited an ATV and I think it was purchased in KY, but I am in WI. Is there a way to do an online search using the VIN or what have you to try and find the last registered owner so that I might try to get the title?
By blasirl
I have found a few useful posts and am looking for a way to bookmark them in the forum. Is there a way to do this?
