What...
By blasirl
Hello all,
New member here and a newly inherited Honda Rancher ES 350. I am here in hopes of a robust How-To section or at least some knowledgeable members that don't mind having their brains picked.
Hope all had a good Memorial day weekend!
By stymy68
I have an unknown year Timberwolf. I have had to replace/repair some back yard wiring issues. With the wiring fixed, I compared to my other Timberwolf quads, I have found a problem. Starter is always running. I can only get it to stop by removing the positive lead from the battery.
By quad-rider53
so i recently got a Suzuki king quad from what i have discovered i think it is a 1994 300 but cannot find serial number i have a couple of questions one is, is the engine oil fill cap and dipstick under the rear right fender??, one other is does this machine have a clutch?? i am not sure if there are any common problems this machine starts and runs and can ride for 5 mins then will conk out and will not start again the spark plug will be wet when removed sometimes i have changed fuel and done other checks but am not sure what is wrong we thinks its carb is being flooded a bit, the old battery will not start it, it just clicks from up near the battery we have been jumping it off a 12v car battery which makes it turn over and sometimes start but about 75% of the time it doesn't does anyone know what might be wrong with it??
thanks Quad-Rider53
By argmore
I have a 97 warrior that sat in the garage for 3 years. I needed to replace cylinder and head gasket. I finally got it done and it started right up. Now my clutch doesn't work. It ALWAYS in gear. The clutch feels normal. I took the clutch cover off and compressed the pressure plate. Everything seems fine except it's always in gear. I'm new at this so please be kind.
Thank you
