* Cleaned this thread up, removed duplicate posts. Corrected video display. You only need to post the url of the video in most cases. You do not need to use the image tag.
OK, thanks. Wasn't sure what to do, kind of messed everything up (as you could tell) and got frustrated so I gave up.
powermadd. i knew it was +10 inches. but thats another 10 inches of weight too
Well,,,,,you have to pick your Material or your Poison Correctly.......Either you add a pound or so.....Or you Flip over Backwards.....
Tell ya what.....Wheelies are Cool with +12:yes: Feels like your 8 Feet Tall:laugh:
    • By spigmef
      I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
    • By Parham
      My 1998 Suzuki Quadrunner starts well and idles steady with no smoke...until ridden.  Here are SEVEN short videos showing the problem.  Please watch in sequence and help me diagnose the problem and develop next steps to repair it.  Videos may be in following posts.  Thanks, in advance, for your words of wisdom.
    • By crochet homemade
      I have bought a 1996 suzuki king quad 300 and I have noticed that it smokes but I have put oil in it and plenty of gas had to fix shifter bc the nuts and bolts came out somewhere. I have had to replace the wire for the starter but now when I try to start it it wont idle at all and when it does run it smokes really bad like a whitish blue I guess, and it likes to stall a lot. So anybody can help me out please and thank you
      10000000_310855426253462_714534016610467840_n.mp4
    • By afa913
      anyone knowwhati need to look at if my 400ex is smoking out of the breather on the valve cover.  I just put a new top end in and it runs great other than that. Too much oil?   Is the breather suppose to have a hose on it? Mine doesnt
    • By mario1978
      i have bigbear 350 1997 2x4 and its smokes when i started it up... for about 3 minutes...
      i changed the oil and oil filter.... wondering is it something serious to worry about? the quad has 10 000 kilometers...seem to run fine to me....bough it for 900$
