outlander560 Posted July 6, 2010 #61 Posted July 6, 2010 2003 arctic cat 400 moose lift kit (modified for IRS) highlifter springs warn 2500lb winch with synthetic rope raider hand guards dyno jet k&n filter outer wears pre-filter removed air box lid 26 inch itp mud lites 12 inch itp delta black rims outlaw EPI purple secondary spring(for clutching) outlaw EPI orange primary springs (for clutching) arctic cat front HEAVY DUTY front bumper "the plow" arctic cat rear bumper other stuff i'm probably forgetting Quote
MIKEL5469 Posted January 6, 2011 #62 Posted January 6, 2011 Started with this 2001 Raptor... Ended up with this.... Quote
MIKEL5469 Posted January 6, 2011 #64 Posted January 6, 2011 thanks dude,that was my project last winter,had fun with it Quote
quadnut20 Posted January 6, 2011 #65 Posted January 6, 2011 nice ride mike:sifonec: is the motor stock ? Quote
MIKEL5469 Posted January 6, 2011 #66 Posted January 6, 2011 as of right now it is other than a k&n filter,and the can,i am going to leave it stock,because as soon as i sell my harley,i am going to get a 700 raptor and trick it out....maybe i will post it on here...lol. Then when i get my 700 , i am going to sell my other raptor... Quote
wylde1 Posted January 7, 2011 #67 Posted January 7, 2011 that thing is awesome, it is too nice for me though, I cant have nice things I am too rough on my toys. Quote
MIKEL5469 Posted January 8, 2011 #68 Posted January 8, 2011 i can tell you this.it doesn't sit in the garage looking pretty,i ride the hell out of it in the summer Quote
drag_on Posted January 29, 2011 #69 Posted January 29, 2011 my 1st ride is a 03 ltz400,95.5bore,+5 crank,P&P,13.7:1, JE piston ,spacer plate,RHC Ferrea +1 intakes valves ,DRZ valve springs ,RHC #187 cams ,DRZ manual decomp ,DID cam chain ,MCCT, no air box ,Sredrum TB 42mm FCR ,RAT stack ,no air box ,WB fuel screw ,EMN needle ,quick shot AP cover ,LTZ 06 clutch TRX450r drive plates w/trx400ex springs, C2HB, ex thumber,04 trx450r air boot, Barker Performance pipe, DRZ flywheel, dynatek adjustable cdi, nerf bars, trx450r shocks, brass steering stembushing ,frame gusseted, nerf bars,+4 swinger ,lowered front & rear ,12 paddle 22X10X8 mods yet to do are; move battey box ,install huge airfilter best dragrace time 5.427 ride #2 04 V 650 AC dynatek cdi Quote
quadnut20 Posted January 31, 2011 #70 Posted January 31, 2011 my 1st ride is a 03 ltz400,95.5bore,+5 crank,P&P,13.7:1, JE piston ,spacer plate,RHC Ferrea +1 intakes valves ,DRZ valve springs ,RHC #187 cams ,DRZ manual decomp ,DID cam chain ,MCCT, no air box ,Sredrum TB 42mm FCR ,RAT stack ,no air box ,WB fuel screw ,EMN needle ,quick shot AP cover ,LTZ 06 clutch TRX450r drive plates w/trx400ex springs, C2HB, ex thumber,04 trx450r air boot, Barker Performance pipe, DRZ flywheel, dynatek adjustable cdi, nerf bars, trx450r shocks, brass steering stembushing ,frame gusseted, nerf bars,+4 swinger ,lowered front & rear ,12 paddle 22X10X8 mods yet to do are; move battey box ,install huge airfilter best dragrace time 5.427 ride #2 04 V 650 AC dynatek cdi This suzuki sounds NASTY!!!! Have you had it Dynoed Post Pics of it Quote
drag_on Posted January 31, 2011 #71 Posted January 31, 2011 i then put on a dynatek adiustable cdi and picked up one more hp Quote
Birddog4x4 Posted January 31, 2011 #72 Posted January 31, 2011 (edited) Some killer MODs/Wheelers! Mine is always under construction. Edited February 3, 2011 by Birddog4x4 Quote
quadnut20 Posted February 1, 2011 #73 Posted February 1, 2011 i then put on a dynatek adiustable cdi and picked up one more hp those are nice munbers man:yes: what mods are next for it ? Quote
drag_on Posted February 8, 2011 #74 Posted February 8, 2011 do new rings count? i did a compression test it was at 60 psi ya id say its time for new rings. no not planing any more hp mods . i did how ever put on a big air filter Quote
Gunny Posted June 9, 2011 #75 Posted June 9, 2011 Fairly new here so I guess I'll add my list to the thread ... even thou most of the bikes seem to be sport bikes ..... :seeyac: 2011 Camo Outlander 800R MX-XT Mods I had the dealer do before I picked the bike up ... :fact: HPG Shocks & Springs Twin Air air filter 3 mode PS unit (for my tracks) Terry Cable Twist Throttle Remove bumpers Remove handguards Install BRP Fender Flares Install shock covers Mods I've done since the bike came home .... :woot: Install Bison Front & Rear Bumpers Modified the Bison Front Bumper Pro Taper Contour Fat Bars with a "Raptor" bend PowerMadd Star Series handguards Removed the Terry Cable Twist Throttle Installed a Terry Cable Dual Gasser Twist Throttle ODI Gel grips Modu-Rak system front & back Roto-Pak gas paks (2ea 1-gal & 4ea 2-gal) Removed the BRP Fender Flares Installed Koplin Defender II Fender Flares Removed BRP Hitch Installed TCC Hitch with Custom tow ring Installed "The Spine" frame stifferner Ricochet skids Dual battery setup with an Odyssey PC680 battery Tamarck Rear Wrap Around Cargo Box Hayden Adjustable Temp Controller Runbberdown 2 inch Lift CVTech Primary Clutch worked by Airdam STM Tuneable Secondary Clutch XMR Clutch Cover Header wrapped the Exhaust Custom CVT Exhaust Snorkel Blocked off factory air box intake EHS Racing Air Box Lid Removed Warn 3000 lb winch Installed 3500 Pro Mark Outback Winch Sold stock tires & wheels Installed 12 inch ITP T7 Beadlock Wheels with a 4+3 offset Installed 27X11X12 Intgeco Reptile tires at all four corners Eagle SNowplow setup Complast Tatou 4S tracks There may be some other mods I did ... but I can't remember them right now if I did. :thinking: Here's a couple photos of it in the garage .... Quote
swampcat07 Posted June 10, 2011 #76 Posted June 10, 2011 2007 Arctic Cat 650 H1 4x4 Automatic LE (Marsh Green) Tires: Trail: Mud Lite XTR 27x9-12 Front and 27x11-12 Rear / Mud: Highlifter Outlaws 29.5x12-12 Front and Rear w/ 1" Spacers. Tuning: 2" Dual Intake Snorkel, Updated Airbox, Duckbill Mod, Black Magic Slip On, Exhaust Snorkel (Bolt On). Clutching: /// Airdam Stage 3, EPI Red Spring. Motor: Speedwerx 700 BBK, Webcam, 11:1 CP Piston, Coolant Overflow Tank Vented Near Pod, Radiator Racked, Cap on Carb Drain. Suspension: Sway Bar, Hockey Puck Mod, All Balls Wheel Bearings and Tie Rods, EBC Brakes and Rotors. Electrical: Auto Meter Temp and Volt Gauge, 4" PIAA Lights, Super-Bright Red LED Taillight Bulb, Circuit Breaker for Fan and Main. Accessories: Custom Graphics by Arctic FX, Hunter Green PowerMadd Star Series Handguards Herculiner on Racks, Bumpers, Snorkels, and Radiator Mount, D Ring Tow Hook and Strap Snow: 60-IN. AC Plow Blade - Modified, Remote Angle Control, and Winter Front Quote
Tagels Posted June 12, 2011 #79 Posted June 12, 2011 2004 TRX450R Durablue +4 X33 axle Houser slicast +2.25 a-arms Houser +1 stem GTT linkage Pro taper contour bars Stock shocks re valved by monster performance Pro armor tether kill switch Pro armor swing arm skid CST ambush tires PRM grab bar Tusk nerf bars Tusk parking brake block off Hmm I think thats it.. Quote
Gunny Posted June 12, 2011 #80 Posted June 12, 2011 SWEEEEEEEEEEET !!! Tagels dude !! :cheer: ... :cheer: ... :cheer: Quote
DirtDemon Posted June 12, 2011 #82 Posted June 12, 2011 Don't know why I just now thought of it, but I thought this thread should be sticky'd, so I done sticky'd it. Quote
Gunny Posted June 12, 2011 #83 Posted June 12, 2011 Don't know why I just now thought of it, but I thought this thread should be sticky'd, so I done sticky'd it. WOO HOO !!! :partyc: Quote
hvy_chevy_one Posted July 2, 2011 #84 Posted July 2, 2011 Im just starting on mine, but so far i have Dynojet Jets, UNI Intake, NerfBars(cant remember what kind), and a biggun exhaust..Hope to ad alot more to it soon Quote
Jonny450R Posted September 9, 2011 #85 Posted September 9, 2011 (edited) uh were to start race-2008 KFX450R-FCI; DASA pipe; pro armor FAT PEG nerf bars; Houser anti-vibe steering stem; Razr TTs all-around; RATH front Bumper; RATH sway bar; ROX speed powermadd hand guards; QuadTech Carbon Fiber Air Duct System; Fuel ATV parking brake block off; Hiper Tech3 rims; stage 2 hotcams; ProCom ECU; PCIII; Flexx bars; ODI Rogue grips, ASR A-Arms on order for the KFX450R-nothing trying to decide to sell it or not:aargh: trail-2009 KFX700-Trail Tech Vapor, bar clamp; Cycra handshields; ODI Rogue Grips; Leo Vince exhaust; Dynatek FS; AC rear skid; EPI Red; Alba's propeg nerf bars; quad boss front bumper; ASR PRO-X Tie Rods; Speedline'z braided front lines;stage 3 Elka shocks; VFJ primary stage 3 clutch with spider mod and custom spring; and fast flexx bars I have a muzzy super pro sitting in my garage that I need to put on, but I don't feel like re jetting and I need to adjust my valves. next weekends projects Edited April 21, 2012 by Jonny450R Quote
Gunny Posted September 10, 2011 #86 Posted September 10, 2011 (edited) Well, in prep for a week long ATV trip starting Sunday, I took the CVTech primary clutch off my Can-Am and Installed a QSC primary clutch today. :coolgleamAc: I then took the stock driven off, took off the stock spring & helix & installed a 650 helix & a stiffer spring. This was recommend by QSC for the altitudes I ride ... :cheer2: And then for Sh*ts & Grins ... I installed a 80mm 60cfm fan in the top of my CVT inlet to push a little more air thru my clutch housing ... or that's the plan anyway ... we'll see if I actually get any real benefit from the fan. :thinking: Here's some pics of the new clutch ... :woot: http://s679.photobucket.com/albums/vv152/GunnyE9/QSC%20Clutch/?albumview=slideshow ... Edited September 10, 2011 by Gunny Quote
quadnut20 Posted September 11, 2011 #87 Posted September 11, 2011 05 TRX 450R Ported Venom Head +1 KW valves -12.5 CP piston - Full Venom exhaust -Dynoed at 50HP fun trail quad and great Dune quad !! Big bore and stroker +3 Next year !! Quote
hangingon Posted September 11, 2011 #88 Posted September 11, 2011 My mods fat 1\2 bald with custom bifocals gray highlites in my side hair 1 hip larger thanks to my quad & a 3 level fusion in my back. Now for my quad Moose power module & tires redone the racks in textured black & have a set of ITP wheels not installed yet & an invisible front bumper. lol some of you will get the bumper joke I think. The title does say post your mods not your quads mods.lol Quote
quadnut20 Posted September 11, 2011 #89 Posted September 11, 2011 My mods fat 1\2 bald with custom bifocals gray highlites in my side hair 1 hip larger thanks to my quad & a 3 level fusion in my back. Now for my quad Moose power module & tires redone the racks in textured black & have a set of ITP wheels not installed yet & an invisible front bumper. lol some of you will get the bumper joke I think. The title does say post your mods not your quads mods.lol QUOTE=hangingon;56584]My mods fat 1\2 bald with custom bifocals gray highlites in my side hair 1 hip larger thanks to my quad & a 3 level fusion in my back From your wife kickin your as* !!! Quote
hangingon Posted September 11, 2011 #90 Posted September 11, 2011 Nope that hasn't happened yet. Thats when the post will read I'm sorry my husband can't type right now and his feeding tube has a knot in it The doctor said theirs a good chance he will not remember this site or how to turn on the computer. Quote
