2007 Arctic Cat DVX400 cutting out
dirtdevil96
I'm putting this in the Suzuki section because my machine is essentially a Suzuki LTZ400and there's more traffic/knowledge in this section. (moved into Arctic Cat Forum..by ajmboy)
I have a 2007 Arctic Cat DVX400 and I recently installed a Pro Design tether kill switch-normally closed(I think;it grounds when tether is pulled)and a Procomm cdi box(+1K rpm & different ign curves).I installed the kill switch as directed(one wire to ground and one wire to trigger positive) and I richened the a/f mix screw as a precaution.I went and rode a couple hard,high rpm test rides and it started cutting out and died.It was very hard to restart and when it does restart it sounds as if a valve is sticking open and it doesn't want to rev for a little while.I got worried and reinstalled my oem cdi and it does the same thing.It runs fine at low/mid rpm and doesn't make any strange noises either.What do you think I screwed up?Please help;thankyou
Edited by Ajmboy
* I moved you into the Arctic Cat Forum and renamed the title thread, which should help to get some replies.
Double check all of your connections to make sure that they are tight. Once you installed your aftermarket parts, did it first ride fine? How long until it started to buck or run rough and then die?
Do you need a wiring schematic? If so: http://www.quadcrazy.com/atvforum/arctic-cat-atv-forum/6869-2007-arctic-cat-400-auto-auto-le-wiring-diagram.html
Thanks for the reply.I tried to edit the title after posting but couldn't get it to go through.That wiring diagram isn't for my machine.I have a 2wd DVX400 sport quad.It has the same engine,frame,suspension,etc as the Suzuki LTZ400.I looked in the Artic Cat section before posting and it was all 4wd posts.That was why I put it in the Suzuki section
I think I have it fixed.I took both the kill switch and the Procomm cdi box off and reset the carb fuel screw to the orig settings as per the jet kit instructions.It still cut out intermittently at high rpm.I was messing with it and noticed the clear inline fuel filter I had installed about 1 !/2 yrs ago wasn't staying full.I set the fuel petcock to prime and it ran better.I ended up taking the petcock off and apart and found some fuzz around the pickup screens.I cleaned out the fuzz and installed a new fuel filter and it runs good now.I'm gonna reinstall the parts I took off and see if the problem was just the fuel restriction or not.Do you think I should put in a bigger main jet when I put the cdi back on?Thanks for the replies!
That's great to hear!
I looked in the diagrams, This is the diagram for a DVX 250, I don't have one listed for the 400 DVX so they may be the same.
I would post the entire document but its too big. it includes all 2007 Arctic Cat models.
Mike
Isn't this for the 400: http://www.quadcrazy.com/atvforum/arctic-cat-atv-forum/6869-2007-arctic-cat-400-auto-auto-le-wiring-diagram.html
I would say to clean out your carb, if you found debris in the petcock then there is a good chance you may have something in your carb. Once you clean it then ride it and see how it runs and if you are still having problems I would play with the jetting a bit, I dont know your altitude or anything but stock jetting can cause problems. Get the spark plug diagram and see how your air/fuel mixture is and take it from there. Also be sure to keep your air filter clean.
    • By Mhatayas
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By NZrider
    • By jatho
    • By mkibbe
