I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
Got a 2011 425 EFI. It eat 2 belts, so I replaced the drive clutch assy, rollers, spacer and movable face. Put on a new belt and after 30 min of riding, it eat another belt. any clue what can be causing this?
Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
