Yamaha Raptor 350 tire questions
I agree that that the Razr 2 is a great tire, I haved used the original Razr and the Razr 2, the 2 is a much better tire, but the original is a bit less expensive. I am running a set of ITP Holeshot GNCCs right now and they are a great tire as well. Personally, I would not run the Mud lite in anything but mud, snow or sand. They are a bit too aggressive for any other type of terrain, at least for a sport quad, especially one without lots of power. It would be a great tire for mud, snow or sand though.
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
    • By Spritee1
      not sure where to look next
    • By mga
