By quadcrazy
QUADCRAZY NEEDS YOU!
By crankin
By harryjr
By BenJammin
I did a compression test on my 2005 Bombardier Traxter 650 CVT and it's 75 PSI. service manual only talks about leak down test. No specification for engine compression the manual. What does 75 PSI tell me? Thank in advance.
A little history of this machine. 640 miles. Picked it up about 2 years ago, not running. Probably the computer. Tested all circuits and confirm it was the computer. Long story short, I watched a Youtube video and fixed the computer. ATV now started and runs. BUT, it tops out 20 MPH. I cleaned the carb 3 times also using a Mikuni carb kit after the second time. Slide in carb is going up and down. Only adjustment for fuel is at 1.5 turns out. NGK Sparkplug had soot on main part but brown on the electrode. Champion sparkplug is brown. I check CVT clutches and they both appear to engage like they suppose to. Checked valve clearance it's 0.00, I can't get any feeler gauges in-between. I check timing chain I believe it's in the correct position and hasn't skipped. I removed muffler plug and drilled into muffler to try and make sure it wasn't plugged.
By joshua91673
hi every one .anyone out there my issue is my kick start wont stay out i have to have some one pull it out. it pull out easy just wont stay out to kick it over .kicks over and starts no problem
also does this quad have a ajust mint for the rear spring .it sags when i get on it .or is this normal . thanks guys for your time
first post
josh ohio
