Join Today, It's Simple and FREE!
Similar Topics
By Dra O
posted a while back - it was running at one point - I have all the plastic shroud off - it's down to frame and engine now
-fuel pump: when line from petcock is attached, no fuel comes out other side to carb; the line to the carb is open (can blow through it); I thought when I cranked engine that the pump would spit out fuel on other side but it does not; I removed fuel pump and opened it up - diaphragm looks good - but internal areas had lotsa calcification build up - I cleaned this out and dried it good - the clear plastic pieces (?diaphragms) aren't broken - the spring w/ steel ball on end moves freely; am putting it back on tomorrow; but can anyone answer about the pump? isn't it supposed to pump fuel through it... to other side... to carb? puzzling
-along with fuel pump: I replaced petcock 3 weeks ago (gas tank had rusty fuel in bottom - cleaned it out prior to new petcock); when I turn petcock arrow NOT to on or reserve, fuel comes out of line; when I turn it to on or reserve, fuel doesn't come out; puzzling
-I don't know what's on back of fuel pump - it's a valve that has a hose coming out of it - looks like it goes to engine/carb - I haven't traced this out yet - what is it?
-can squirt gas on air filter and engine will run for 2-3 seconds then stop - fuel in top of carb (under diaphragm) does same
-it likely needs carb rebuild - will get to this - but something isn't allowing fuel to get from fuel pump to carb
-I THINK it has a mikuni model x carb - diaphragm is ID 26mm OD 68mm - hard to find inexpensive diaphragm, I guess because it's a model x
-last thing - I replaced solenoid due to old one clicking; I HAVE to be charging the battery or it won't start/turn over - battery just goes dead; but if charging, it'll turn over nicely; i'm guessing it's a bad battery
-any help appreciated - I've never owned an ATV before - inherited this beast from grandparent in-law
By pcumby
Hi guys I'm in the market for a new ATV. I narrowed my choices down to King quad 750 Grizzly 700 and Rubicon 520, I own a 2006 500 Rubicon right now and I like the reliability and power for plowing. However it is not a capable ATV. When quading with other guys it falls short with ride quality and ground clearance. I also have a 500 King Quad 2015 which I like and will keep it for my wife. It is very strong and reliable also. However my plan is to sell my Honda Rubicon and replace it with a 2020 of one of the these mentioned above. Can anyone give me their take on one or all of these machines and why you picked what you picked?
By Daniel Gibson
Have a 08 raptor brought to me a couple months ago. Got it on a trade for house remodel. Bike has around 30 hours. No that's not a typo thirty verifiable hours. The main Yamaha tech has put hands on this bike. Always Been reallyhard to start. If it does it runs really good. That's the kicker...IF! It started out intermittent now it's no spark at all. Everything ignition related is brand new. It all checks out good but still won't do it. Please help
By Gunny
So, what did you do on tax day ?? Me, I went for a track ride even thou it was foggy and snowy ... Hope you enjoy the winter time video ... ... -
By Asen_77
Hi All,
Can anyone help me with file for new Yamaha Raptor 700R 2020 design
I want to put this on my Raptor
Thanks to everyone in Advance for any help!
