I just put in a brand new cam and a brand new cap and it just did the same exact thing is there something that holds that cam or decompression ring in place. Also I noticed another thing when I started it disconnected the battery ran like it was supposed to hook battery back up couldn't hit the gas again. I'm getting so frustrated with thing its unreal about the hundredth time I've taken it apart.
Holy crap a second failure!!!! Ok time to take a breather and really look into this to see what’s happening.  That is a serious failure.
Without disturbing too much try to open the head up see what’s loose or does not look right.   It’s almost as if the engine is kicking backward ?
It will go in 2 different ways but I put it in exactly how the service manual showed it both times now before I put it in and wounded the spring once never had this problem now manual says put it in with spring in relaxed position do not wind it once it will not work right but both times broke the case out like something is throwing it out the busting the weight off and weird thing it started running perfectly when I unhooked the battery its getting so much juice from stator it blew my neutral light out this is crazy I just keep throwing money at it and just keeps costing me more its insane
It happens. We all (is flippers) get that occasional machine that does this to us. Best part is when it’s figured out and running good it’s worth the work.  So walk away and do some research and between you and Quadcrazy there will be a logical answer.
Is the flywheel keyway intatact?. If the keyway is broken can also get an erratic voltage which can  take out the regulator/rectifier. Also can cause issues with timing and cam walk.  My manual state a 1/4 preload on the spring and that the cover is also a cam thrust plate
I went and got a new cam yesterday it doesn't even come with the spring preloaded which sucks. Right now I'm trying to find a cap before I can try it again. Just worried to break another one
Also ? How on earth can the motor go backwards some where on hear someone said sounds like the motor went backwards how can that happen
That can happen if the engine backfires. Usually if timing is off or an unusual amount of fuel that builds up in the cylinder.   The engine kicks back.
Can you screen shot the page that explains the cam and spring installation and post it here ? I want to read it. I don’t have time to start looking for the manual
    • By RadRob
    • By DPDISXR4Ti
      Thanks...
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
