That was straight off the stator from wire to wire the ohms dont match manual thru exciter coils either whoever had it b4 me bought stator and voltage regulator new well when I test exciter coils there 513-521 ohms manual says 446 so makes me think something is wrong I honestly think they bought a 96-97 stator colors dont match even close to what there supposed to.
That is off the stator output
No way. Barking up the wrong tree. What’s your DC voltage at the battery when idle? Ultimately, your spark runs off of DC voltage. HOWEVER...there used to be a problem where the magnets were flying off the flywheel and there are two types of flywheels. The one that had the problem had four magnets and the newer ones (the good ones) had 6 (if I remember right). I could see a problem if they replaced an old style flywheel with a new style flywheel throwing off the pickup. But tell me your DC voltage at the battery at idle.
Another thing to check: do you have a timing light? Use that to see if it’s actually losing spark when you give it gas. And what happened with the shot of carb cleaner test when you gave it gas?
Edited by BuggyMasters
That still would not make sense for the voltage to jump all over the place like that. Even if some of the magnets are gone OR the newer flywheel with the additional magnets was in place the voltage  should be stable if the engine is spinning at a constant rpm like it was explained? It jumped from 18v to 22v at idle ? How could the voltage change if the rpms did not ? My money would be on a bad stator. I do however find your information on the flywheel a very interesting point.
The job of the regulator is to smooth and stabilize / along with handling you AC/DC conversion. So you had 12.7 DC at the battery with everything hooked up correctly or are you saying 12.7 without the regulator hooked up? The more important measurement on the stator is each of the 3 primaries to ground in which there should be no continuity. Usually when people change the stator it’s because the battery is not charging. I want to know battery voltage with everything hooked up at idle. The flywheel magnets being correct is relevant for the sake of the pickup. I just can’t remember the specifics but seems that it’s ok to have the newer flywheel so long as you have the matching newer stator. New flywheel and old stator/pickup coul is not going to work if I remember properly.
So with everything hooked up, what’s your DC voltage at the battery and where I am going with that is if at idle it’s 12.7 and when you give it gas it goes down to 7, I could see that causing it to cut off as that may not be enough juice for the coil to function. And obviously if you only have 12.7 at idle with everything hooked up you clearly have a stator/regulator issue. I’d probably go with a Ricky Stator replacement ignition system.
Ok heres how I tested it I fired up the quad it was idling the voltage regulator up front tested 2 primary stator wires right there 18.7 so plugged those back in switch meter to dc tested that 12.6 well that was working right so I took stator wires back off now its 22.2 ac so I revved it up a little it went to 40v ac that's phase to phase
But the only thing that cares about the AC voltage is the regulator. The entire rest of the machine is only concerned with the DC. So the entire rest of the machine, including the ignition circuit, only cares about DC. The two components before you have DC are that stator and rectifier/regulator and those would be considered either good or no good and as a general rule their status will be based on the DC voltage. If you don’t have 13.6 (or so) while running at the battery you replace either or both of those components. In my experience, the stator is pretty typical. You usually find one of the coils going to ground and its bad. Period. I have absolutely seen stators ohm from lead to lead out of spec and it ran fine. Maybe it would charge a little stronger or weaker than one in spec but it would not keep the machine from running. So for that reason and also the fact that the solid state rectifier’s job is to manage the AC voltage, I have never cared about the AC voltage. If you replace the stator with a known good setup (with verified correct flywheel) and you still have either nothing over 12.6v or you have something high like 15vdc+ then you replace the rectifier. I personally feel you will drive yourself nuts chasing variances in AC voltage. (Been there done that and ultimately the solution was always to replace the stator or regulator). Also there is one other variable and that is the Polaris machines used to use this stupid box called a SureFire box. I just can’t remember if the 500’s used them. For sure on the 325’s and 330’s. If you have one of those sure fire boxes, they are notorious problem devices.
Yeah that’s the old style flywheel and what I would expect on a 99. That stator almost looks aftermarket. Any brand on it?
If it was me I’d be ordering a new Ricky Stator just to take it out of the loop. Just make sure the stator is specific to your year. That one that is in there absolutely looks aftermarket. I just looked on eBay and as I expected the factory ones do t look like that. Looks like China brand. I mean I think you are having to fix someone else’s cheap as* approach.
Yea but has to be created somewhere ground just dont come out of thin air especially for dc current now I'm a master electrician of ac and dc I no a ground just cant appear pole wires are connected to ground by earth ground which is just the neutral but ac is coming from generator in the bike then has a wire going to ground inside the stator that has to ground the one leg of the stator to create a ground to the quad
That’s what I mean is it’s gotta come from somewhere in order for the path to exist. I am assuming the stator or rectifier provides it or something, I mean all four wheelers will run without a battery so they are getting it from something. Never really researched the details of from where.
Wow just got in from working on my project bike you guys covered a lot. Great topic discussion. So I’m assuming your going to order a new stator as discussed earlier and I think that’s going to solve this erratic voltage problem. We see a lot of people asking about wiring in an aftermarket stator that does not match up like an oem part.
Hopefully this will solve your problem.
Nice work so far and @BuggyMasters great input!!!!
Keep us posted!
Theres a wire that bolts to the bike from the stator almost is cut through from the flywheel I'm buying a new stator no matter what but has to get a ground from some where in look. Fly wheel almost cut it through but when I first fire it up with a new voltage regulator today perfect 14.8v on dc side soon as I revved it up just a little stalled now I cant even get 7v on dc side so I'm getting a new stator screw all this and voltage regulator and going from there with American parts this is bs
    • By buriedpast
    • By DrtyGrlKristin
    • By LMI
    • By MikeDB
      Greetings to all.  New to the forum, but not to ATVing.  I started when they only had 3 wheels!  Getting back into riding.  Polaris 850.  Too many bells and whistles, but what do you do.  Scouting out places to ride legally now.
