  • 2 years later...
I downloaded it and it is a complete service manual. It does have the electrical prints. I work on different types of 4 wheelers so I will put this one in my saved files. If you need help, I will help as best I can. Here is an electrical print from the manual. The white area is the ignition and start system. This manual has the prints separated into sections for the area you are troubleshooting.
    • By Fonne
      Hi
    • By Arizona
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
    • By quadnut20
      Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into  ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
    • By davefrombc
      I added a pdf of  the wiring of the various connectors used in vehicle socket  and trailer plug wiring to the  "Other ATV files"  section in downloads.
