I need a engine for a 04 500 tbx. My dads quad was really messed up by a local dealer they cracked the engine cases. I have now taken them to court got some coin from them and want to find a wrecked quad or junk yard that has a motor. Because a tear down part by part would cost way to much. Let me know what sourses you all have.
Thanks cway
No I still have not found a engine but I have not been looking that hard. I keep watching e-bay and the salvage yards but nothing yet.
Yes it is a Suzuki Motor I know that I just don't know if the two will interchange. After looking I have not found any Suzuki 500's either. I am looking into putting a 650 H1 in it, I have to change the wire harness, Head pipe, and cdi for starters but it would give it more balls.
Motor mounts are easily moved, new mounts are often the easiest part of a motor swap. Depending on how different the motors are, clearances and intake/exhaust plumbing are the most difficult part IMO. Are the 650 and 500 motors based on the same design? If so, the bottom end may bolt in the same, it may just be the top end that needs modification.
i was looking at the diagrams of both ur 500 and the 650 h1 and their very similar especial the mounts.. the only thing that was really noticeable was the exhaust and the top left side engine brackets... besides that their very similar.. and the intake as well is pretty similar the only thing was the exhaust pipe shield on the 650 which the 500 did not have
  • 6 months later...
I have heard that the suzuki 500 will work,and they look like it will. I have a great running bike i'm thinking of parting out on ebay,its just that there hasn't been enough sold on there recently,and i dont want to put everything on there for nothing.but if i could guarantee to sell the engine,i would consider it. Email me @ [email protected] if you want to talk more.
    • By digrig
      Hey everyone,
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
    • By shorty
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
