By tepin
By middlebrookgt
By C2INS
Hi everybody! Just wanted to introduce myself coming from NBTX. Got some used Honda TRX250's this year and have been hooked on more fixing them up than actual riding right now. Probably could use some help from the folks here on getting 2 of them in proper running order, but I'm sure I'll have to post that elsewhere!
But anyways, glad to be here and looking forward to chopping it up with y'all!
By spigmef
I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
