Similar Topics
By Myrtsbnye
Hello All,
I have a 1996 Arctic Cat Bearcat 454 and am in a bit of a quandry. I had a bunch of work done on it over the past couple years...new carb, rear brakes, rear axle and bearings. When the rear axle was replaced the shop noticed the left rear hub was stripped. Problem is, the part (1502-178) is no longer available. I've checked junkyards, ebay and other online parts sites across North America and nothing available. Hate to park the bike after all this work just because of a simple hub.
I have two questions...the front hub (part number 1502-177) how much different would it be from the rear hub? This part is readily available. Would the axles be different diameters?
If these are two different parts and we can't make them work, is it possible to take the existing stripped hub and just weld it to the axle? I know it may sound drastic but was wondering if it would not be too crazy?
Thanks for your time
By gatorschevy
I own a few older quads mix of kinds a couple of Yamahas, a Honda, can-am a Kawasaki, they are older quads but in good shape the question of the day is....... what's the best way to polish up the plastic?
By MMC
I have a Suzuki Quadmaster 500, that I got from a customer. It has less than 400 miles on it. I think I put most of the miles on it, so they sold it to me. I used to drive it a few times a year, treatinjg the gas or emptying it when I could.
I relocated and wanted to get it running again. It will start with little trouble, then run for 15-20 minutes, then start to chug a bit, then finally stop. Sometimes I can start it again, but it doesnt continue to run long after that.
when I first opened the oil filter when I moved, it was drenched in oil and fell apart. I went and replaced it with a OEM foam filter. I notice now, when it does stop, there is a small amount of oil on the bottom the air filter box, and it's clean oil. I had recently changed the oil before I moved. Each time I clean that up, I go through the same process. It will run, and I can drive it for a bit, but then it slows down and stops.
Any suggestions? I am not an ATV mechanic by far, but can work on most of the stuff I own. I did have trouble finding a dealer who would work on it. One local one, said "We dont' work on stuff that's over 20 years old" It can't be because of parts, I just laughed.
By Fish0rDie
Was told there was some good information on this forum, so I'm here engaging in some good ole conversation haha. Bought a buggy aka shitcart for 100 dollars. Thing was a woods toy for the past owner. Used and abused until she went boom and was left in a field to die. All things considered that may be an exageration, but the top end of the warrior 350 that was on board was absolutely mangled. Piston and head assembly were totaled. Have a new jug, piston, and head assembly, but struggling to get the crankcase back together without the transmission binding. Can share pics that are on my phone if anyone is interested in seeing this shitty story unfold.
Similar Tagged Content
no spark Yamaha YMF 250 Bear Tracker No Spark
- bear tracker
- yamaha
- (and 1 more)
- 21 replies
- 7,201 views
- 0 replies
- 2,893 views
- 1 reply
- 3,503 views
- 1 reply
- 2,646 views
- 0 replies
- 2,969 views
Gallery Images
