i have a 2001 arctic cat 500 that has started back firing and cutting off. it seems to happen more after its been rode a bit but at no particular speed....it will crank back up but continues to try to die and back fire and eventually dies again..any advice on where i should begin looking to fix this problem????
check for a short in the ignition switch or the kill switch, make sure the plugs are in good shape first, i would put in news just to be sure. a bad connection at the battery can cause a problem like that also.
hope it helps
pontiacjim
Hi, just a suggestion but try setting the valves. I have a 2000 ac 300 and a 2003 ac 250 and once they got a few hundred miles on them I had to start adjusting the valves for hard start and backfiring.
    • By tepin
    • By cruteg8
    • By Shorty51
    • By cruteg8
    • By sunn
      Any ideas?
