Video of my holeshot
Similar Topics
By Kidshavebrokeme
Hello, Im looking for some help instead of spending hours on You Tube. Got roped in to buying the above Kazuma 110 I think. I've worked on all brand of autos.
thought I could tackle this butttt. No start no spark. My stator is producing a faint light by ground. Buy the meter I get 337 ohms on the
black, red wire. Some of my questions, Can I bypass everything to look for spark. Can the plunger type kill switch be removed an both wires put
together to help achieve spark that is behind the seat. My black red to the cdi has no power to it when turning over. Should i put some form of
lubricant in the plug hole or are these motors moving the oil enough and should the plug be in or out or does it matter when looking for spark?
I'm thinking the wire for the coil from the cdi should light up the test light and it does not. (Forget its color at the moment). I hope there's not a limit
of questions cause i will have more and Im not much for typing. Any help would be just jim dandy and greatly appreciated. Thanks Steve
By MikeyC85
Hey guys and girls - I’m at a loss and need your help!
My jianshe 400 ML has been starting great on pull start but nothing on electric. Narrowed this down to starter clutch so have changed this and now engages fine.
problem is since changing she struggles to turn over. Had it hooked up to a car battery just to see if it will flick over but to no avail.
Has Spark
Has fuel to carb
absolutely fine turning over with spark plug removed.
Any clues appreciated!!
IMG_0315.MOV -
By Parham
This quad was a hot mess two weeks ago when I got it. I've been tinkering on it and have it running pretty good. It didn't have a pull start. I just got one and installed it today. Here's a little video of my first try at using it. Hope it's worthy of a "onya" from Mech! 🙂
IMG_3274_Trim.mp4 -
By Ulfthednar
The Dog loves the runs.
https://youtu.be/tKjBFuHCkM0
Similar Tagged Content
- 8 replies
- 1,987 views
- 6 replies
- 2,379 views
- 2 replies
- 2,088 views
- 0 replies
- 1,208 views
- 3 replies
- 1,664 views
Gallery Images
