what do you use your quad for
By DracieVajko
Hello, I cant find any solution... The problem is that battery isnt charging.. I located and meassured alternator cable, there was like 100-150Volts in cable that is going to the voltage regulator, but the output from the regulator that is going to the battery, I guess, was without any power, just 0 volts.. So I replaced voltage regulator but didnt helped. On fresh charged battery on turned atv is there around 13.5 volts, when I push gas the volts goes up to 13.6 maximum but the battery still isnt charging, by time it just drops down to 12volts and less again. I have no idea what is the problem here. I would appreciate every help. And sorry for my bad languagge :).
By loudsubz
Where do you guys shop for oem/aftermarket parts? I'm new to the ATV scene and only purchased a few parts so far from Amazon but may need some more specific parts in the future.
By utvboard
This Rear Seat Setup from Hot Ride is Plug and Play. Setup includes Crow Seat Belts, Lock & Ride Plugs and all Mounting Hardware. The cage uses Polaris' Lock & Ride System along with 2 mounting Safety Pins to install and remove easily with just two people. One complete piece that drops directly on the factory Lock & Ride mounts. The design is functional and easy to install for cruising, but can then be easily removed for serious riding.
Available from Hot Ride 4 U, Bakersfield, CA
Phone: (661) 587-7702
Website: www.hotride4u.com
More...
By Guest
Is there a way to add a check box under the Quick Reply box to either sub or not sub to a thread?
Tom D
