fixed quad broken rider
Got the news monday I have 2 disc in my neck that I will be getting injections too. Friday I see a Dr. for carpal tunnel surgery. I'm not sure yet but I know I want be able to ride I am not sure if I will be able to use the computer. I might just end up setting around in tears till I can ride and type again!
Well I got to ride 3 friends came over & after a week of rain we hit the trails and had a great time. I'm going to make the most of it. My surgery for the carpal will be wed. 28th the doctor said it can take 3 months to fully heal. I hope I can ride before that.
good to hear you were riding! :yes: lucky duck! hope the surgery goes well, doc's always give worst case scenerio for recovery too, maybe 1 1/2 months is all. i broke my collarbone and doc said i'd be out of commision 4-6 weeks, 3 weeks i was back at work! mind set!
    • By Werewolf
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By Spritee1
      not sure where to look next
    • By Johnfj44
      The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
