introducing myself
By smallmotor2002
Hello everyone.
I'm working on a 2014 Yamaha 700 Grizzly and having no luck accessing the diagnostic mode on the display. I have tried with the fuel pump connector plugged and unplugged, and select and reset buttons depressed simultaneously for up to 30 seconds with no luck.
I could sure use some assistance if anyone has any tips on this
By ATVNetwork
By Randomnumber73
I'm working on my uncles grizzly and it sparks once on initial cranking then no more after that. If I let off the start button then press the start button again it will spark once then stop sparking. I was wondering if anyone seen this issue before. Also I've never used forums before so sorry if this question is in the wrong location.
By Sportsman500guy
By DZL1
Thanks in advance.
