What to wear?
By Jd101506
Hi all-
I’ve got a LT300e that I’m working on. The last two days I noticed as I’ve been testing it, it won’t turn off with the key. The kill switch still works to turn it off, as does everything else (lights, neutral light, reverse, starter, etc). So I guess I’m taking votes on what to do here… Ignition the issue? Wiring grounding issue somewhere?
Not sure where to start so any help would be appreciated!
By bigdgr
Just got the quadrunner. Seller showed it would start and run a few seconds on ether. I ordered a new fuel pump and installed it. Put 2 amp charger on battery and tried to start-NOTHING. No lights come on , etc. Acts like battery is dead but it isn't. HELP Please!
By Bedrock_Engineer
My Yamaha big bear keeps on locking up on a right turn. It didn't do that before sending to mechanics. I don't know what the problem is, any advice is appreciated.
By robren
What might cause the outside half of my right front tire to wear way faster than the inside or other tires? 07 650
