Hey I have a 97 bayou 300 2x4 (klf300b) that i bought for 1000 last June and sunk another 1000 into it already.  When i went to look at it, the seller had warmed it up before hand (he was riding it when I got there).  it ran good so i bought it and took it home that evening... next morning it wouldn't hardly start.  I discovered the carb was clogged, there was chunks of rust in the fuel valve, the choke lever was missing and other things.  I have since cleaned the carb and replaced the fuel valve and gas lines and cleaned out the gas tank and cap.
Enough background on it, the problem is this:  It floods if i push it past half throttle in 4th and 5th gear even going downhill and shifting correctly.  It also has to idle and warm up when you first start it which is really annoying now that its cold...  It also smokes blue smoke for about 15 seconds when started cold-  does not smoke at all once warm but the exhaust still smells like burnt metal.  A friend told me that it didn't have enough compression.  I also found out that the valves are a common cause for low compression on Kawasakis..  I have never adjusted valves before-  the most I've ever got into a engine was a head gasket on a riding mower so I'm new to this.  My goal is to get this bike running and starting cold like a top-  should i tear down and rebuild the top end?  What should i try first?  I tore the carb apart and rebuilt it and fiddled with the air screw and nothing changed.  I also ordered a compression test kit that should be coming in soon.
Ive also considered just selling it for like $500 and taking the hit-  Id rather not sink too much more into this machine..  lol
Welcome to Quadcrazy! Nice looking bike.  I’m not sure how mechanically inclined you are but if so then I would keep the bike!   My guess is since you see blue smoke it’s most likely bad valve seals if the smoke goes away after it’s been running.  It’s a valve seal kit you can buy and install. If your not familiar then we can help as well as you tube.  If the blue smoke is constant then maybe a piston and rings may be in order.
As far as the carb goes and if someone had tinkered with it before then my guess is the needle on the carburetor is set wrong. This can be adjusted very easily by following the throttle cable down to the carburetor and unscrewing the slide from the carburetor and making the adjustment on the needle.
Its a clip on the main needle in the carburetor  Go to YouTube and you will see how this is done.  As well as Quadcrazy helping you along.  Looks like a good bike  but don’t feel obligated as I have a live for old bikes  especially since yours is in such good shape
1 hour ago, 06kfx440 said:
Well. Blue smoke is burning oil. Could be bad seals. Flooding is a float issue adjust to spec.
I have cleaned and inspected the carb thoroughly three times now-  the float is not sticking or anything, and its not adjustable to my knowledge.. correct me if im wrong tho.
You are not wrong just not aware. I have attached a pic for you to see.  This is an adjustment to the needle hight inside the carb.  To high the carb will result in too much fuel being delivered.  So take a look and see. Maybe a long shot but def worth looking into. Put the clip at the second to last high spot on the needle and try that. Most common spot is in the middle or second to top. Also Manley sure all the meats are clean.  After that I would go with a fresh plug and check the spark. Just to be sure it’s a good clean spark.
https://youtu.be/7lnURLsBIHg
Sorry make sure all jeys are clean . ***
Jets* dam spell check!
Can you send a link to amizon or ebay for the valve kit?  I'd rather not get the wrong parts..
https://youtu.be/7lnURLsBIHgimageproxy.php?img=&key=01ee6617cc17ea3cimageproxy.php?img=&key=01ee6617cc17ea3c
All the jets are clean- I removed everything I could and cleaned everything with carb cleaner.  I will get another sp soon to make sure that works.
Athena (P400250600300) Top End Gasket Kit https://www.amazon.com/dp/B00PLS6ZXW/ref=cm_sw_r_cp_api_77R6BbVRTF3VG
Carb cleaner is great but sometime you have to run a small wire through the jets to be sure they are clear.   I also like to blow air through the jets to be sure they are clear.
I like to use  a piece of wire from a bicycle brake cable, one strand of that.  There are also small brush kits for cleaning carburetors on amazon as well.
  • Ajmboy changed the title to 1997 Kawasaki Bayou 300 2x4 (klf300b) Runs Bad
Thanks, that's a lot better price than the rebuild kit I looking at for $140.  Thanks.
So, I will check the compression, replace the sp, and get this kit for the valves.  I will attach a picture of my carb-  It doesn't look like the one the YouTube vid..maybe the former owner put in the wrong carb?  I dunno..
It’s very possible it’s a cheap aftermarket carb.  Is there a name on the carb ? A pic would be great.
Also keep in mind that you will need a valve spring removal tool to take out the seals.
Its cheap enough but not a tool we all use that often thank god !
It’s posable that it’s an aftermarket but I can’t be 100%. But by the looks I would say yes. Hears my issue with the aftermarket if it is one.  I’ve purchased one before and put it on my Polaris 90. Bike fired right up and ran good for the first 3/4 throttle. After that it was a hot mess.  So I picked up a used factory carb and rebuilt it and put it in the bike.  It ran great.  I took the cheaper one apart to see what was going on and found nothing!!!!  I put it back on the bike to see how it performed and the same thing.  Go figure.  Not quite sure what’s what but it was def someplace in that carb causing a problem. Maybe the casting when made but not sure.  I am a big fan of oem replacements. Just the way it is. I would try to locate a used factory carb, rebuild  and put that on so you can put that end to rest.  As far as valve seals....  that should stop the burn off you are getting once replaced.
Loop the carb and all the used/new carbs look exactly like my current carb.  And all of them are at least $75.  Should I just eat this or what?  There doesnt look to be ANY difference between the oem carb, the stock used carbs, and my carb.😰
If Im gonna have to pay that much for a carb, I'm probably gonna try that valve seal kit first:     https://www.amazon.com/dp/B00PLS6ZXW/ref=cm_sw_r_cp_api_77R6BbVRTF3VG
That’s the thing with the cheap aftermarket carbs. They look identical and appear to be spot on. I’m not saying not to go ahead and try it but I’ve just had no luck with them.  I like using the oem carbs.
Def curious of the compression reading when you take it.
Keep us posted.
Awesome I bet you can’t wait to get started on the seals! If you look at one of my older posts I tore down my bayou 400 and did the valve seals.  They were probably fine but since the head was off i figured might as well do them.  Plus the seals came with the gasket kit anyway. I should have bought the valve compressor tool but wound up making one.
Super important is the timing! Make sure your at TDC and the “T” mark on the fly wheel and the timing marks are where they belong on the top end  pryor to removal and dont rotate the crank during this process If possible. You can always put it back if it happens but I like to leave it right where I took it off.  Also take a few pics during just in case you need to take a look back.
Valve cover bolts are all different  lengths so number them with a sharpie and tape.
When reassembling use plenty of lube/grease on the lobes and moving parts to avoid friction during the  initial restart.
After reasembly just spin the motor a few times without the spark plug just to make sure everything is smooth and oil pumps up to the head.  👊🏻
I flirted with the idea of buying a cheap aftermarket chinese carb.  In the end I just bought a carb kit.  Let the carb sit in the cleaner bucket for a couple of days, cleaned it up and installed the kit.  Runs great now except for the electrical gremlin I need to chase down.
I was advised not to get into the valves by a friend that used to work on small engines.  I ordered to seal kit already so what should I do?  Should I get into this having no experience?  I want to learn how to work on engines but I'd rather not screw up my bayou.  The friend advised me to sell it as is and take to hit..  I'm thinking 'well I have already bought the seal kit soo'
also, I fouled my sp on it at my friends house.  It started as usual when I put it on the trailer but when I pushed the starter button to unload it, it turned over fine but it didn't fire.  The sp was maybe 2 or 3 months old.  Happens my friend rides a Honda Recon and got a new sp in the mail that day so i tried his old one in my bayou and it fired up but still ran as usual.
compression tester came in this evening:  it holds at 60psi (4bar).  Anyone know where its supposed to be at?  its a 97 bayou 300  (klf300b)
    • By quadnut20
    • By kevinohio
    • By HHurks
      Thank you!
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
