ok.  I took the head off and losened the cylinder and pulled it up a little so the rings would still stay compressed.  The cylinder moved pretty freely up and down.
I also shined a light down the timing chain and around the crank.  no kinks.
So the piston is jammed inside the cylinder it sounds.   I would back the piston out and see if that’s the problem.
If the crank spins freely then the piston is jammed inside the head and that’s not good. You can scratch the cylinder walls.  Maybe a rings not compressed and sitting in the groove right.
I hate to say it but I would pull the head again and see if the crank spins. You have to be sure that nothings inside the engine.
Habs you tried to spin it both directions.  I feel like it would have to be the timing chain. Be sure it’s all the way up and not kinked down below.
Ok, looked it up, for the forum:  In:   .10-15mm
                                                    Ex:   .20-25mm
I got it as close as I could- the valve clearance tool I bought didn't go that small...  just down to .20mm so I just tightened it farther on it to try and get down to .15mm.  If Its running bad, I'll get a different set and get it exact.  Any tips as I put it back together?
So timing and valves are good ?
If so just re tighten everything good and spray a drop of wd-40 into the cylinder and spin the engine a few times to get the piston up and down the cylinder.
Did you put the new rubber rings in the valve cover caps.  I like to use a drop of high heat scilicone on the edge of them caps. They leak oil for some reason.
lastly  after it’s all back together I like to  press the start button with no spark plug in to cycle the engine a few times to pump oil up into the head before it fires up so it does not scorch the cam.
I would do a quick clean on the carb just to make sure it’s giod to go and nothing’s in any of the jets.  It has happened before.
1-3/4 turns out on the fuel air mixture screw from a snug position.
Put the air filter back on before you dial it in with the final adjustment.
Floats prob stuck.
You can try to tap it with the back side of a screwdriver to maybe free it up.
    • By quadnut20
    • By kevinohio
    • By HHurks
      Thank you!
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By en4cer
      Problem number 1,
      Problem number 2.
      Any help would be nice.
