Suzuki king quad 300 idles great but Boggs when you apply throttle
Go to solution
Solved by 97kingquad,
By HSTAR
By NZrider
By hardcastle
By Whiterabbit
3500lb, synthetic rope lead and everything needed to install for........................................ $89 bucks! I'm installing one on my '01 Bombardier Quest and it looks like a legit buy. If you have a RK nearby & you need a winch you might want to swing by before they disappear.
By Tuzz
Bucking started about a month ago and works ok after 1/2 hour warmup. Today while working on it i discovered that if i put the ignition switch in LIGHT position it runs fine right from the start.
I'm stumped! Any idea why this could be?
