Anyone using a plow? What Brand? And are you using a winch or handle? Any reccomendations? I see a bunch out there... Warn, Moose, Cycle Country...
Here's a Swisher plow I seen online:
  • 3 months later...
You made the mounting kit yourself? Nice! That ozark is 2 wheel drive right? How do you like it? Is it a 250?
Yes it is 2 wheel drive 250. I love it for plowing snow! I also put a 60 pound weight on the trailer hitch. I made the mounting kit at work. I,m a steel worker. The place I work for is Nucor Building systems. We produce metal buildings.
Have you fabricated anything else? Bumbers, skid plates, etc?
Just a yard wagon. I waiting for a friend to recover from an operation. So we can build some bumpers.
Edited by BuckBilly
Nice...I remember I was looking for bumbers for my 05 king quad when I got it because there were none available yet. I was thinking of having something fabricated at the time. Now they're all available.
Back to the plows, have you seen this by warn?
truckstuffusa_1955_51303248
ATV Plow AG Adapter by Warn,
Allows the plow to be rotated up to 50-degrees
I plow with a 54" Cycle Country on the King. This year I bought the down pressure kit from Cycle Country. Works great! Now I can even back plow without an issue.:yes:
i have 2 plows ... i modified the mount bracket on 1 and made a bracket for the other .. they are ...a wheelhorse and cub cadet ... i use a wench to raise an lower ... they are heavyer built than most of the plows you buy for quads ..
  • 4 years later...
    • By WeeBee
    • By Tim Keiper
    • By roggers
      Hi everyone,
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
    • By drag_on
      I have 3 atv's 2 have winches , the problem I sometime have is loading onto the trailer if the bed is wet or of frosty. there have been times the winch is needed. but , what to do if the w/o ATV  or any other perhaps dead ride needs to go onto the trailer . 99.5%  of it came from harbor fright.
