By 97kingquad
By TravisCr
I don't know if I shouldn't have posted but I this is my second post on this (other was in regionals Forum) The family has a 2-up 2004 Artic Cat and a 2003 Polaris Sportman and we are looking for fun/easy rides in the Colville, WA area- 70 Miles North of Spokane WA, we have a small trailer we can haul these with but need to find some good areas for beginner.
Thanks in advance for any suggestions.
By TravisCr
By That229Yamaha
Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
By 1FSTLS1
2006 Suzuki Eiger 400 4x4 runs fine has new tires. Garage kept just use it once a week to take the trash to the street. I got it about 8 years ago. I put a starter and battery in it about 2 years back. Has light bar and heated hand grips. I got a 6x6 and no longer have use for it. Zip is 25411/25422 WV.
Brad
304 six seven one - 179eight
