The irs takes a bit to get used to. Jumping is not bad at all, but going over whoops, the rear end likes to kick back up on you. Sliding is a whole new animal cause the outside tire grabs . I've only lost to a highly modified yfz450. As a whole I'd rate it an 8 out of 10. Flying on the trails takes a little body english but its a blast! Good deals on them are getting hard to find. Honda stop making them after the
'09 model. I highly recommend that you get one if your in the market for a 700.
Barker Duals, HDD5050 cam, K&N filter, CFM air box, CP Tech piston, +3 throttle body, Bo White Track 2 head, PCIII fuel controller, AC nerfs, AC bumper, Flexx bars, ODI grips, ASV levers, Billet ebrake block off, Billet gas cap, Chromed timing plugs, QuadTech seat, ITP Baja wheels, ITP XCR tires, Skat Trak Hauler paddles and Mohawk fronts...
Nice Rappy !! Get it Dynoed you`ll love the resaults ! I can`t spell !:laugh:
  • 2 years later...
  • 7 months later...
400ex high comp piston, titanium valves, bronze valve guides, fully ported head with port matching done to intake/ exhaust, decked head, enlarged header opening, big gun eco for 450r, 45pilot 175 main, stage 2 hot cam, polished rockers, 5 angle valve job, k and n with outerwears, 14 tooth front sprocket, stock rear, 18 in rear tires - stock front - cst ambush, red o ring chain, wheel spacers with extended studs, trx250r rev box, dg nerf bars, ac bars, moose racing grips and clutch perch, new throttle/clutch cables, 450r axle nut, new starter, and much more.
  • 2 years later...
3 minutes ago, Gunny said:
Why THANK YOU Quadnut ... and Dang, I sure hope so !!! Glad you enjoyed the video My Friend & THANKS for watch'in too !!!   :notworthy:
Yea I was bored so i figured Id check out QC !! Dont see many of the old members around ! I see people have to buy memberships now , when did that start ?
This pic was taken last weekend in Colorado , We have some great snow for riding here !!
Well, I'm glad you enjoyed my video. That looks like a wild bunch already to tear up some snow ... WOO HOO !!!
yep were doing snow rides every weekend !! My quad is good up to about a foot of snow but speed is the trick !! PS Ive showed ur vids to my buddies and they like them also !!
Edited by quadnut20
Right On !!! Going out every weekend sure beats pull'in weeds doesn't it !?!? ...... :chatterboxn:
Why THANK YOU for shar'in the vids My Friend !!! It's much appreciated !!! :notworthy::notworthy:
    • By Need-help-with-quads
      Can anyone help me?
    • By semicolon
    • By HSTAR
    • By ResQ91
      Hi guys
      battery and connections good
    • By McG75
