2003 Yamaha Warrior 350 Overheat and Gas/Air Mix Problems.
My Warrior seems to be overheating on me. I live in Metropolitan Arizona, and I expect to have some issues with heat ,but not this bad. After about 30-40 minutes of riding it wants to die on me, the only thing to do to keep it from dieing is keep it revved up at idle and between gears.
Tell me what you think about that issue.
The next issue is that my Gas/Air mixture might be off. I don't know which screw is the mixture screw, I know which one is the idle screw. And I do know thats it all the way in 2.5 turns out on the mixture.
It needs a new throttle cable and will come eventually. I'm just trying to fix these two issues for now.
And last issue, but I think its more so related to the gas/air mixture.
I takes FOREVER to start my quad. At least 10 minutes. I know its not getting enough air (or too much gas) because I had to take three of the screws out of the air filter cabin to get more air into the carburetor. When the air filter cabin lid is screwed down with all 5 screws it takes forever to start Full choke, about 10-15 minutes, and 50-75 cranks (tallying an almost dead battery), but when its propped open with a tire plug tool, it doesn't take AS long. Full choke, about 3 minutes and 25-35 cranks later!
From my understanding a finely tuned ATV should only take a minimum of 2-10 cranks to start on full choke. Could there be some other issues with my carburetor besides the gas/air mixture being off? Like like the float or the jets? Please, any help will be greatly appreciated.
Nathan L. Mesa, AZ
Take the carb completely apart and clean it well. The fuel screw is located on the bottom of the carb in front of the float bowl. I'm not sure, but I think the idle screw is on the left side of the carb, but I could be mistaken. How long has it been since you cleaned your air filter?
Edited by DirtDemon
I got the quad early august of this year. I haven't done any thing to it, besides replace the running switch (I've heard it called a dead man switch) on the handlebar, not the PB Switch but the one above it. I've have taken the carb off and taken it apart somewhat but didn't notice anything wrong with it. I handed it over to my wifes dad who works on primarily transmissions for vehicles. He also works on Artic Cats (don't buy them he says!!!) as well as all the other ATC/ATV/UTV brands. He said the jet wasn't clogged, but I get the feeling he didn't really look at it. Other than that, put a new battery on it, took it out to Butcher Jones, took it up a hill, rolled it, it was still running till a couple hours before we packed up and were getting ready to leave. That's when the problems happened. Actually we were having problems with it the night before on the way in to Butcher Jones. Every 15 minutes or so, it would over heat and completely die. Couldn't start it up until it was semi-cool. Eventually got it into the first cove of Saguaro Lake. Had it parked most of the night, but decided to attempt a hill, that's when I rolled it. I caught from rolling a second time, and started it came back down the hill and parked it, because I was all banged up. Later the next day, we rode the he!! out of it. Then randomly someone got on it to take it for a spin, and that's when it would start and idle but as soon as you put any throttle on it, it sounded like it was misfiring HARD CORE!!! Let off the throttle, it idles fine and starts all day. Took it to my wife's dad he noticed that the running switch was broke, snipped the wire, uncrossed them, started up and ran just fine. Not a single problem after that. It doesnt have the over heat issue as bad now, now it takes about 30-40 minutes of riding before it wants to die. I'm so flustered, I don't know where to begin.
To answer your question, no, I haven't cleaned the air filter. I will do that tomorrow, and see if it changes the performance. I'll use gas to clean it and wait for it to air out before I attempt to start it. I will let you know more tomorrow.
Nathan L. Mesa, AZ
sounds lean to me. you should have only 2 screws on the carb: one for idle and the other for mixture. pull your spark plug and see what color it is, let us know. white is too lean, black is too rich. that will tell you where to start.
If it is lean it WILL run hot.
I snapped a picture of the spark plug, its not even 2 weeks old about 2-3 hours max on it. Here it is... Photo0160.jpg
And another better quality picture
For only a few hours on it, it sure does look like it has darkened quite a bit.
That plug looks pretty normal, if you chop the one side of the threads off the plug and take a look at the lower part of the insulator, it will give you a better idea of your air/fuel situation. You could still be running too lean on the pilot, or the needle clip may need to be dropped a notch. If you spend alot of time at low to mid throttle, and the pilot and needle are set too lean, that could be causing the overheating. Take the carb apart again and make sure that the jets are completely clear. Poke a small wire or something through them, soak them with carb cleaner and then blow compressed air through them. Also make sure the floats are adjusted properly. Also, improper ignition timing, dirty, gummed up cooling fins, improper valve adjustment and low grade or dirty motor oil can cause overheating in an air cooled motor. You also may want to install an external oil cooler.
Thank you DirtDemon, this should get me headed in the right direction. If none of that fixes it when I get the money, I will pm you if it doesn't work. Should be like a month or so.
Could the magnet on the flywheel be a possibility?
You say it is over heating. How do you know? If it is just dieing after a time it may be some other issue. It may be a coil getting hot and not working. Also check that the fuel line is not routed near the cyclinder or head. Does the engine oil smell burnt at all? Try running the bike on reserve instead of on and see if that makes a difference. Pull the fuel line off the cacb and check fuel flow as well. Just some other stuff to check. Another thought,next time it dies on you, pull the plug and see if there is spark. If not , it is electrical. If there is, is the plug dry or wet? Have you ever tried using the choke when it dies to see if it helps at all?
Edited by handyhiker
Ok so here's an update. I went out and tore the stator/flywheel cover off my Warrior. Timing is correct. the compression is great, and it gets fuel (probably too much because I can pull the spark plug out and its wet) but it doesn't get spark, it only gets spark when it gets a little warmer (I don't know what gets warmer to cause it to start like that, but it literally takes me a whole battery to get it to start) But being now that its December and its a high of 60 degrees here in AZ. It won't start at all. No matter what I do.
I was in at my local Yamaha Power-sports dealer a while back, and the pro said "when its a Yamaha with electrical problems its 9 times out of 10 a stator issue". Which leads me back to the first part of this post. I sanded the points of the stator with 120grit wet/dry sand paper to see if it would help, including the inside of the flywheel where the stator points float nearby, I sanded the discharge point and the strip on the outside of the flywheel that touches the discharge point. (keep in mind it was a light sanding, I didn't get into it, put a lot of pressure or time into it, just enough to freshen the surface of all the points. Still nothing, it just turns over and over with no ignition. I think I need a new stator, my carburetor's air/fuel mixture screw is frozen so I cant tweak that at all. I snapped a float arm off inside the bowl area of the carb. I JB Welded it back on because its pot aluminum and is not TIG friendly.
I did some plasma cutting/welding on it over the weekend to put some nerf bars on it, I disconnected the positive side of my battery, can someone tell me if I might have possibly screwed the CDI in the process of welding/plasma cutting.
About the carburetor, I plan on spending a little money on my quad, and getting a +7mm crankshaft and a 1mm over piston. Instead of spending $300 on a stock carburetor, I was going to spend a little bit more and get an Edelbrock carb (rated at 24.3hp) for $400-450. Is it worth the investment considering I want to turn my Warrior 350 into a 396ish cc motor? Any and all help will be greatly appreciated!
You say it is over heating. How do you know? I DON'T KNOW, If it is just dieing after a time it may be some other issue. It may be a coil getting hot and not working. Also check that the fuel line is not routed near the cylinder or head. ITS NOT Does the engine oil smell burnt at all? FRESH ENGINE OIL THE PREVIOUS OWNER PUT IN, SO I CAN'T TELL. Try running the bike on reserve instead of on and see if that makes a difference. IT DOESN'T Pull the fuel line off the carb and check fuel flow as well. FUEL FLOW IS FINE. Just some other stuff to check. Another thought,next time it dies on you, pull the plug and see if there is spark. I WOULD IF I COULD GET IT TO RUN. If not , it is electrical. If there is, is the plug dry or wet? Have you ever tried using the choke when it dies to see if it helps at all? NO, BECAUSE IT WON'T RUN NOW BECAUSE OF SOME ISSUE, OTHERWISE I WOULD CHECK AND SEE IF USING THE CHOKE HELPS WHILE ITS RUNNING BUT TRYING TO DIE
So, it's not runing at all right now? Are you even getting spark?
Here are some textbook answers to overheating on a Warrior:
Overheating:
Firing incorrect:
Spark plug dirty, broken, or maladjusted
Spark plug incorrect
IC igniter trouble
Fuel/air mixture incorrect:
Main jet clogged or wrong size
Fuel level in carburetor float bowl too low
Carburetor holder loose
Air cleaner poorly sealed, or missing
Air cleaner duct poorly sealed
Air cleaner clogged
Compression high:
Carbon built up in combustion chamber
Engine load faulty:
Clutch slipping
Engine oiHevel too high
Engine oil viscosity too high
Drive train trouble
Brake dragging
Lubrication inadequate:
Engine oil level too low
Engine oil poor quality or incorrect
Coolant incorrect:
Coolant level too low
Coolant deteriorated
Cooling system component incorrect:
Radiator clogged
Thermostat trouble
Radiator cap trouble
Thermostatic fan switch trouble
Fan relay trouble
Fan motor broken
Fan blade damaged
Water pump not turning
Water pump impeller damaged
There are tests you can do with a multimeter, I would suggest buying a manual. If will have directions and specs for the electrical tests you need to do, and it will have other info that you will need to do motor work, like torque specs and wear limits. The first thing I would test is wiring, connections, grounds, and switches. There are a few switches that could be keeping your ignition from even being turned on if they aren't working properly.
To test coil:
Touch one of the meter probes to the lead terminal. Touch the other probe to the ground. Replace the ignition coil if it is out of specification.
Primary Resistance: 0.18 - 0.28 Ω @ 20°C (68°F)
Here are electrical specs for you:
Ignition System DC C.D.I. Magneto
Generator System AC Magneto
battery Capacity 12V 12AH
battery Type GM12CZ-4A-2
Headlight Type Bulb Type
Headlight Wattage 30W/30W
Taillight 5W
Brake Light 21W
Neutral Light 3.4W
Reverse Light 3.4W
Voltage 12V
Ignition Timing (B.T.D.C.) 10° @ 1,000 rpm
Advanced Timing (B.T.D.C.) 33° @ 5,000 rpm
Advancer Type Electrical
Magneto F4T466
Pickup Coil Resistance 459 - 561 Ω @ 20°C (68°F)
Rotor Rotation Coil Resistance 0.083 - 0.101 Ω @ 20°C (68°F)
C.D.I. F8T38675
Ignition Coil 2JN
Minimum Spark Gap 6 mm (0.236 in)
Primary Winding Resistance 0.18 - 0.28 Ω @ 20°C (68°F)
Secondary Winding Resistance 6.32 - 9.48 kΩ @ 20°C (68°F)
Spark Plug Cap Resin Type
Cap Resistance 10kΩ @ 20°C (68°F)
Charging Current min. 12A or more at 3,000 rpm
Charging Current max. 17A or more at 8,000 rpm
Charging Coil Resistance 0.83 - 0.101 Ω @ 20°C (68°F)
Voltage Regulator Type Semi Conductor-Short Circuit
No Load Regulated Voltage 14.1 - 14.9 V
Rectifier Capacity 14 A
Rectifier Withstand Voltage 200 V
battery Specific Gravity 1.280
Starter DB5DT
Out put 0.7 Kw
Armature Coil Resistance 0.011 - 0.013 Ω @ 20°C (68°F)
Brush Overall Length 12 mm (0.47 in)
Brush Overall Length min. 8.5 mm (0.33 in)
Brush Spring Pressure 650 - 950 g (22.9-33.5 oz)
Commutator Diameter min. 28 mm (1.10 in)
Commutator Diameter max. 27 mm (1.06 in)
Mica Undercut 0.6 mm (0.024 in)
Starter Relay MS5D-611
Amperage Rating 100 A
Coil Winding Resistance 3.9 - 4.7Ω
Fuse 15 A
No luck, I found a deal on RMStator.com for the Stator, CDI, Ignition Coil Spark Plugs, Pulsar Coil Pickup, Krypton Light Bulbs, and the Flywheel Cover Gasket for $200 and for another $100 for the Voltage Regulator/Rectifier. I plan on putting some work into my quad, like getting a Stroker Crankshaft +7mm a +1mm stroker piston, an Edelbrock 24.3 rated hp Carb. So I'm going to replace all of that stock crap with higher performance parts. I did test the CDI and two of the wires were testing fine. around 460 ohms. Never tested the Voltage Rectifier, didn't feel like it. :aargh:
Just an update, I am going to order the Banshee YFM350X Haynes Book for my Warrior 350 for electrical specs and engine stuff. I got a $50 Amazon gift card for christmas that I'm going to use for that. I am going to replace all that stuff mentioned in an earlier post about the RM Stator deal. Don't know when, probably as soon as I get an extra $300 to spend (probably tax return season). I have to take my carburetor in to work so I can mill out my frozen air/fuel mixture screw, put a helicoil in it, then get a rebuild kit for a new pilot screw. I have to order some HTS-2000 Brazing/Soldering stuff for the pot aluminum float arm I snapped off inside the bowl area of my Carburetor trying to disassemble my carburetor to soak it in some Chem-Dip to clean it, and break junk free and nylon brush it down. So as soon as I get the parts, probably mid February I will update again. Well I'm going to go out to my quad and take my carburetor off right now to see if i cant get that pilot screw/'air/fuel' mixture screw off by hell or high water. See ya then, Nathan L. Mesa, AZ
Don't order a Banshee manual, a Banshee is nothing like a Warrior. Neither the motor or electrical systems share any similarities aside from displacement. You can find a manual for a Warrior if you look for it. Try Ebay. I hope you haven't ordered it already. I would just find a used carb on Ebay or at a salvage yard, along with a rebuild kit, that will be far easier and probably even just as cheap or cheaper than trying to repair the damage.
Update: That Banshee Warrior Haynes catalog gives separate specifications for both quads. It really is an In-Depth manual.
Update: Got a new carb (used from a guy parting out his quad). Got it rebuilt, pilot screw was perfect, had to replace all the throttle linkage, float pin, float, and bowl. But I still don't know if it works, because the quad still wont start. I put a volt meter up to the spark boot, and ground. While trying to start it supplies .25 volts, while not trying to start it supplies .35 volts. I have a feeling its my ignition coil, my voltage regulator, my cdi, or my stator. or any combination of those 4. I have perfect timing, and great compression. I don't have spark. The pilot screw of the carb is all the way in and out 2.5 turns (which I believe is the correct placement of the pilot screw). I am going to replace the Stator, pulsar coil pickup, CDI, Ignition Coil, and voltage regulator. If none of those fix it, could it possibly be my relay fuse? Any additional help would be great. And I will repost when I get my electronics installed and tested. Hopefully this fixes it.
I just looked at my Haynes book and it says 1 and a quarter out. So I will reset that tomorrow, and recharge my battery, and try to start it again. I have a feeling though that it won't start. I have a question. Is there any adjustment in the Pulsar Coil Pickup (Pickup Coil)?
Judging by the low voltage at the plug wire, I would guess that your coil or coil wire is your problem. An ignition coil should put out thousands of volts, as much as 20,000 volts. If there is an adjustment for the pickup, it should be mentioned in your manual. There should be a direct resistance test in the manual to test your coil. If the coil tests ok, it could be the voltage regulator/rectifier.
Check that coil like DD said..sounds like it could be your issue. Actually your post said you are replacing some electronics. Let us know how you make out. I would start with the coil first.
Well like you suggested I pulled my ignition coil off, and checked both Primary Resistance and Secondary resistance, and they both showed an infinite resistance. I tried all functions within the Ohm range. 200 2k 20k 200k 2m 20m and 200m, and they all show a solid "1" on my multimeter. Also on my multimeter on the 200 ohm range it beeps when you make 0 ohms or No resistance. Like either touching both meter probes to each other, or a piece of metal like a soda can. It was not making the beep sound when I tested the Primary, but I still got a Solid 1 on my multimeter. When I tested secondary resistance, I got a beep at 200ohms and a solid 1 on all ohm settings. What does this mean?
I've tested every possible combination, and I get a Solid 1 and a beep on some of the possibilities, but not all. I'm so confused. I went ahead and ordered a new Ignition Coil, I get the feeling like this one is shot. Either its getting infinite resistance or ZERO resistance. and the specs call for on 2002 and later in my haynes book... Primary Resistance: 0.018 to 0.28 Ohms; Secondary Resistance: 6.32 to 9.48 K-ohms, I can tell you all, thats not what I'm getting, unless I don't have a multimeter in range to test these ohm levels out. But my multimeter doesn't even flicker. Can someone tell me if i'm in the right direction ordering a new Ignition Coil, or what?
Much thanks for your time and help. I've only been able to ride my quad a handful of times after getting it, and I really want to take it out soon!!!
When you test the primary resistance, you should have the meter set to the 20 ohm range, 200k ohm range for the secondary resistance test. If you are not getting the correct readings then I would start with the coil. It really seems like that is most likely the problem given the low output to the spark plug. I would test all of the other components before you go and order the coil just to see if you have any other problems, but I think you will end up finding that the coil or the plug wire is the main problmem. It may be a good idea to check the connection of the plug boot to the coil wire. You may try unscrewing the plug boot and clipping back the coil wire just a bit to make sure you have good fresh wire at the end, then screw the boot back on and try the coil test again.
  • 2 years later...
Hi I have the same problem, my valves tick but are in spec, I put them into spec today and started it to let it idle and about a minute later I turned it off, the pipe was realy hot, like crazy. Maybe it should have been and I'm an idiot but I'm pretty sure it was a little too hot for only running for a minute, I couldn't even touch the header for a second. Please help me out!
Ok I was reading a problem you have. Mine had a problem with idle and got worse as it got hot. Found something simple wrong with mine. Check the intake boot between the carb and head. Mine had a crack in the rubber. The worse the crack got the worse it would run. Sucking air like crazy.
Check that intake boot!
    • By Tim Keiper
    • By neilroy87
