So are we gonna have this wheelie contest thing or what? I think we could pull it off without anyone getting seriously hurt. We did have one for "Best front wheels up". Maybe just do that one again.
I think thats a good idea !:yes:I`v seen 4x4`s wheelie !!
guess we better sweet talk this idea to the head honcho's here huh quadnut20 and all? :laugh:
I've wheelied my quad. It's heavy as hell, 4x4, and has plenty of power!! Did I mention it was strapped to a tree trunk in low range? :) I should have gotten pictures but I was on the seat. Got the stump out with a little effort. I might have to try it again on a new stump, just for the picture contest next month.
This guu is quite good!! With a little practice this could be Ninasatv
Sent from my SGH-T959V using Xparent Blue Tapatalk 2
haha, idk about all that...besides im more of a trails kinda gal. even if i do get my front wheels up it wont b for long or i would hit a tree. (never saw a superman wheelie before)
.... and not be afraid of cracking your a$$ a few times (cuz its gunna happin) :yes:
.... you will wheelie .... :yes:
i dont know if i am up for crackin my as* again...think im good ;)
ive only had it happen to me once and tht was because i was hill climbin and it came up right at the top ...... i couldnt sit it back down cause i dont have back brakes:laugh:
I'm not understanding how you guys are falling off?
rappy must not wheelie very much cause it does happen sometimes.... like i said though its only happened to me once but tht wheelie was not intensional:laugh:
I wheelie all the time. I don't stand on the grab bar, kneel on the seat, or sit down though. Maybe that's why? I stand up while I wheelie and turn my handle bars so I can grip really well.
  • 4 years later...
    • By mehim
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
    • By Need-help-with-quads
