By BillR94
By BuckBilly
Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
By johndeerefarm
Is there any way to mod an Outlaw 50 to increase the speed? The size is perfect just would like a little more top end speed. Thanks
By p5200
I added more fresh gas it sat one day now, it's acting up again. Before cleaning out carburetor it wouldn't idle good and had gas leaks from carburetor. Now it idles pretty good but, if I increase throttle speed at a certain amount it starts missing bad. I'm going to try and post a short video. Just about ready to give up on this thing.😒 you can see reflection perking in video.
20240217_114429.mp4 -
By trieck1232
I recently was given a 2005 Chinese ATV, No marking what so ever other than on the side of the head it says 10cm3, which i think means that it is a 90cc? Trying to figure out which cdi it needs, as I have diagnosed that i am only geting .1 v at the coil, it also has a alarm (no fob) which ive read you can just unplug to bypass, i have the vin number it is l5nsumcc45t009855 but that isnt helping much... The motor cranks, but no spark checked the kill switches etc.
