Suzuki king quad 300 idles great but Boggs when you apply throttle
Go to solution Solved by 97kingquad,
  • Admin changed the title to Suzuki king quad 300 idles great but Boggs when you apply throttle
If cleaning the carb fixed the high low idle, i would check the fuel flow to the carb and make sure it is getting good flow and maybe the float height. If it ran good for a few days and then all of a sudden not so good, it may not be charging and the battery voltage has dropped.
Make sure the carb isn't letting gas leak into the throat. My King quad did this and I could only figure out what was going on by looking into the carb while the bike idled. I attached the video of what was happening and a picture of the piece that I needed to replace. Also changing those o rings didnt fix the problem bc it was leaking from the center circle where the needle goes.
Edited by DayBreakJim
17 hours ago, Mech said:
On those things there are about five bits that position the needle.
I positioned the needle to the fourth from bottom and reset the fuel screw to recommend setting. I'll see how it runs now and go from there
Randy, I've known that for about ten years before you'd ever experienced the problem and came into forums looking for advice about it.. Even my early teen sons knew about it before you..
The difference is that we all know it can be a dirty or broken wire, That it's not always a dud regulator like you reckon..
Okay so I went through and tested the regulator rectifier/ stator and it seems I'm not getting almost any voltage.
Would that cause all this fuss?
It ran great for a few days and now it will only idle if I rec it up it Boggs and dies if I don't flutter the throttle.
My battery was dead before when it ran well also and it doesn't change when using a booster pack.
Maybe it just doesn't get enough volts at higher rpm?
Actually Randy..  I was just thinking about it because it's so comical, and I knew about it before my sons were even a twinkle in their mum's eye, and they are thirty and thirty-two now, and they were both familiar with it when they were about fifteen, maybe twelve.
Er.. What's that little tick under your name tag there about Randy, and why do I have twenty-one under my name ?
I saw you going looking, clutching at straws in the old threads..
You're an idiot Randy and you just don't want to learn..
Oh are we allowed to call people names now?
It doesn't matter because slander is the tool of the loser.
It's your narcissism score.
21 poor souls got terrible advice.  It's a shame I could only save one.
Yeah well we'll let people decide that for themselves.
You "logic", if that's what you call it, goes something like this..
R  I skidded on a slippery road and had a crash once.
M  Perhaps you dozed off, or were going too fast, or your tyres needed attention.
R  No, only slippery roads cause crashes. Nothing else but slipper roads cause crashes, and here's a whole heap of newspaper clippings to prove it.
M But Randy, I could find you a whole lot of newspaper clippings showing that speed causes crashes too. People should slow down and make sure they aren't tired and check their tyres. Every police department says to slow down and check your tyres. It's well known that speed can cause crashes.
R No, that's bad advice.. People shouldn't slow down or check their tyres. That's bad advice Mech.
Yes sir..
Like you say Randy, the internet is a big place and we can't hide from our posts..  I know when you got into quads, I know when you first had a regulation problem, I seen you asking for help to diagnose it..
But, like you also say, you just come in here to argue..  And like I keep saying, I come in here to help people, and you Randy, can't be helped..
You carry on, someone might feel like a stupid and pointless argument, but I have trouble lowering myself to your level of stupid.. I can't oblige you.
Yes sir..
Looks like you forgot to take your meds, Narcissus.
You totally ignore the guy wanting help while you pout and cry.
If it ran great with a dead battery that is evidence that the regulator is faulty.  It's a known issue on these quads.
The higher the rpms, the higher the voltage will be unless the regulator regulates it properly.  Once the voltage gets to 18v the cdi will not function.  Having a dead battery will act as a regulator and lower the voltage so the engine will run better.  That's why Mech said to try turning the lights on to see if it runs better.  I taught him that a year ago and he can't stand it.
15 hours ago, Gwbarm said:
Thats a good thing to do 97, do you mean you are not getting any voltage from your stator, or regulator. What about the pick up coil.
Stator, I unclipped the wiring that comes from behind the rear tire and tested with my multimeter and I read less than 1 volt on all of them
Ok so I tired switching the headlights on but it makes no difference from what I can tell.
I have removed the carb at least 20 times now adjusting the needle and set screw but none of it has had any impact on my issue. The only thing that has made the bike run better and hit any higher rpm is actually removing the cover from the air intake. It runs almost well.
I know it is not supposed to be like that but I really can't figure it out. There's no debris in the intake and the carb is pretty clean. The Jets and vacuum lines all seem clear.
Why does it need more air? Even when I max out the set screw it starves for more
15 hours ago, Mech said:
You need a good battery in it 97. Try switching the headlights on and see if it makes a difference..  The lights will provide the load the battery isn't.
But it was running great without one shortly before all this. And now when I remove the airbox cover it runs pretty well but backfires here and there
@JustRandy and @Mech can we all just get along...lol. Your help is invaluable to the community and greatly appreciated, so lets not argue. What a great scenario to have different points of view and contribution to solve an issue, but without the derailing of the topic and name calling please... Sets the wrong tone. 🙂
Are you aure you sparkplug and coil are good ?
It's not good enough just looking at the sparkpklug when it's out and sparking, they can fail under load.
You also need a good battery and it's very likely here that you more than one fault.
Do you have a timing light ? Put it on and watch it while the bike starts to faulter. If the spark get intermittent then the spark is breaking down.. But that doesn't test the spark plug.
    • By Brent Wright
    • By vlxerdon
      Don
    • By DexKing
      When you and a group of friends decide you want to take a long group trip of camping/riding/overlanding, how far are you willing to drive for your trip? Right now, i find it really difficult to want to drive more than 2-3 hours one way.
