I believe my cooling fan switch has gone bad, the dash goes out except the over heating symbol flashes but the engine is not hot to the touch. So i used a jumper wire from hte accessory side of the ignition switch, so the fan runs if the key is on. A new switch is about $110.00. Has anyone else done this, will it be ok to run like this as long as i check for overheating manually? Or should I replace the switch?
You should replace the defective part, it may be a sensor or a relay. Relays are cheap, I would start there. Check the wiring in the circuit, look for loose connections and make sure you have a good ground. Operating the fan manually is ok for temporary, I would use a toggle switch that you can turn on and off while riding. Run the fan when you are working the motor hard and any time where you aren't going fast enough to get good airflow through the radiator, otherwise you shoul be fine with it off.
I agree, it may be arelay and running it on all the time will just burn your fan out prematurely. If you have to, run a toggle switch. It's very possible that it's a coolant sensor issue.
Add a three position switch, on, off, and auto. Some put a warning light for the off position. Then you can use the on position until you get everything fixed, the off for water crossings, and the auto for when you are back up and running. If you need schematics let me know and I will see what I can do.
Yup, what he said^^^^^
Thanks for adding that. I created a new thread with your wiring diagran and sticky'd it, to help others who may be searching for it.
http://www.quadcrazy.com/atvforum/arctic-cat-atv-forum/6869-2007-arctic-cat-400-auto-auto-le-wiring-diagram.html
That isn't the complete document, only the one page of it that refers to the model he had a question about. The document I have covers all 'Cats from that year. The original document is a bit over 4 megs. Attached is the index page.
(Weird, I can attach PDF's but not JPG's )
2007 ATV Wiring Chart index.pdf
Create an account
Register a new account
Sign in
Sign In Now
    • By Frank Angerano
      I’m looking for any member that may be familiar with the neutral safety switch on this bike.
      I picked up a bayou 220 that I found sitting in a shed. Nice looking bike the guy said it would not start one day and put it away and never touched it again.
      So it turns out the neutral safety switch is bad.  I jumped it out and the bike fired up and runs good.
      I’m more then capable of the work in changing it but this thing is buried pretty good. I’m curious if anyone has done the switch replacement before?
      I attached some pics to see.
      picture 1 is the side view you can see the green and red wires going into the cover.
      Pic 2 shows looking down on the drive shaft coming out of that cover.  That is not a simple cover you just pull off.
      Im wondering how deep and how much sh** has to come off like the drive shaft etc for this switch  to be replaced.
      So if any of the QC members have done this switch I’m looking for any input with regard to changing it.
      Thanks.
    • By heath
    • By DaveswMN
      Thanks for any thoughts.
    • By lester
      I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
