I used my old LG Ally Android powered phone. I had a speedo app on it before I got my new phone so it still worked through GPS.
In about a block I had my Yamaha Warrior 350 up into 6th and up to 49 mph. Was still gaining speed but had to slow down. Was coming up to the Stop sign so I figured the block was long enough. I believe I read the top speed is around 60 to 65 for the Warrior.
Had my 350 over 65. Not sure on the 700, but should be in the 95-105 range. Never got that fast on a road, but topped it out in a field and i could tell it was spinning awfully bad. I know for a fact it will do 63mph in 3rd gear.
found a quick was to convert your tire size for accurate measure of speedo....
take your tire size you have now (in my case 27) multiply by your speed (94 kph) and divide that buy your stock tire size (25) and this will be a more accurate speed. 101.52 kph
27 x 94 = 101.52 kph
25
  • 3 months later...
Had my '06 YFZ450 up to 71mph at Silver Lake right before I shut it down. Start to get really light and hairy.
Covered the 1/4 mile in 7.62 @ 179 in a Super Comp rear engine dragster back in the late 90's.
My r does the same thing ! The front end starts to float !! :laugh:
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
    • By crankin
