Sounds like it may be the age factor setting in on shutting them down early. I'm sure when I was 20 I would have kept it pinned. :)
BRAINS kick in !!!LOL at 55 I find it harder to heal from crashes :laugh:
LOL, I have the same feeling about hill climbs anymore.:no: Takes me longer to charge up them.
even at the age of 28 i still have to think more about what i go up. if i get hurt and cant work then i dont have money to pay the bills or go play. but i still find myself going up hills that i shouldnt .
:laugh:When i was 29 I had no fear !!!!
my kfx 700 go it up to 78mph according to the time slip I got the one time I took it drag racing. my kfx450r going up pikes peak I was averaging 65mph. the 450 would have been faster if I was lighter and wasn't going up hill. :laugh:
Edited by Jonny450R
I know what that's like. Third time I had mine out I went with my son and my son in law on some dunes east of town. Flipped the Cat coming off a dune and broke a rib. Took 3 months to heal.
To answer the question, I got the Cat 500 up to 62 once.
  • 5 months later...
Hey Swampcat, It was Mike Penlands' quad, and he knows the ins and outs of getting speed out of a Can-am. His son Hoyt, (who passed away in 09') had it up to 95 before the race, when they were testing it. Epic racing also had an Outlander that was very modded, and it was supposed to be able to top 110. It had the front diff taken out, some serious long travel shocks, and more than a little "extras".
I am hoping we have good luck this coming November, when we try it again. I am hoping that maybe for 2013 we can run Baja in a Commander. We both would like to give it a try.
I got my old prairie 650 up to 56 mph I have to backout of the throttle at that point. It starts getting unstable and starts wondering due to the tires I have. I was told it will reach 70 mph by the shop owner where I bought it. I don't have the nerve to try.
Start with the Mavrick and you have a good base with 110hp stock. Good luck and be sure to post pics if you do.
Calling you out on this... What tires, gearing, and RPM were you pulling to make this happen?
20inch box tires, geared down on the rear sprocket and up on the front sprocket. a good friend of mine is a sheriff and clocked me on several runs, 119 was as fast as i could get it.
Going down or up 1 tooth on the front sprocket would be equivalent to going up or down 3 teeth on the rear.
I do hope you understand your motor would have to rev up to 13,100rpm to reach that high of speeds with that gearing ratio.................
yes IF i ran those ratios of course, i went down like 8 teeth on the rear and up 2 on the front. It's not like 2 strokes are hard to get more revs out of anyway...
the max rpm's for a bone stock banshee is 9000. But it all depends on your modofcations. Banshee's with the power valves like the 421 cheetah's will rev up to 18000 RPM"s
No. A 421 with Cheetah cylinders wont touch 14k let alone 18k... Either way, it's not possible.
i know i ran 119 mph on my old banshee, I SAW THE RADAR GUN WITH MY OWN EYES... rather or not your agree i can care less. I KNOW WHAT I SAW...
as far as the 421 Cheetah cylinders, i have only been told this and have not looked it up for my self.
my bad on the 1800 i meant 10,000 rpms. yea 1800 is NOT gonna happen on a banshee LOL
since you do not seem to understand, iLL TAKE YOU TO SCHOOL...
i ran a 16 tooth front sprocket
i ran a 30 tooth rear sprocket
this gives you a 1.875 ratio with 20'' rear tires
the banshee's Primary Gear is 2.869 this is at 10,000 r.p.m's for a built banshee.
Yamaha banshee Gear ratios are as follows
1.st gear ratio is 2.461
2ed.gear ratio is 1.812
3erd. gear ratios is 1.500
4th. gear ratios is 1.250
5th. gear ratio is 1.045
6th. gear ratio is 0.875
so technically speaking it would run 126 mph, this minus the tire friction and wind speeds produced there for i ran 119 mph and not the full 126.
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
    • By crankin
