Similar Topics
By quadandy
Hey guys! Stoked to be here because ive found its pretty hard to get help for mini quads
I recently bought a mini quad (it's a piece of poop so i have no clue the make) and it ran perfectly fine. I was running it a few weeks ago all day and it worked fine and the next day when i went to start it, the kickstart bar was super hard to push down but i could still do it, then it would skip and finish off hard to push down.
I have fairly intermediate mechanic abilities so i was able to pull off the cover and start playing around. it seems the kickstart spring is fine but i noticed a bunch of metal shavings. long story short i posted pictures and took a video of how things are kind of running. i assume the gears started grinding and now they wont catch fully, hence the skipping?
Also, im aware the main gear on the left has broken teeth, i found out the hard way when i tried to take off the nut and the teeth broke.
IMG_7447.MOV IMG_7445.HEIC IMG_7446.HEIC
By KRAZZYGUY
Has anyone had experience installing an in-line water heater? It gets to -20 F here in the mountains and I had problems last winter. It looks like they get spliced into the coolant hose. Runs off of 120v and has internal circulation pump.
By Johnnyhorsepower
I finally found an awsome app for your phone that shows you on a map all the trails near your location. You can read or add reviews, look at picts...etc
Its called: atv escape
John
By Kawinoob
So title tells all. achine was sitting for two years untouched.
I will post a picture with diagnostic path so far.
Replaced defective start solenoid, starter grinding but engaging.
Replaced all wiring in #1 splice with dark green, brown and red/white wires. Checked all other junctions.
Pull start works phenomenally and starts instantly.
Kill switch does absolutely nothing, but the key will stop the bike and allows it to start. Replaced key switch and pigtail at key switch. As of now all lighting is functional (was not before fixing it)
The Good:
-has new spark plug
-valves were adjusted
-key switch
-wiring appears in order after repair
-display functioning
-new battery
-always starts easily on pull rope
-etc switch
-pulsar coil
- ignition coil
I am replacing the bendix due to intermittent failure and gapping the pulsar tonight. Also, replacing battery cables and unplugging kill wire from cdi to isolate. Replacing battery wires to starter and ground cable.
Similar Tagged Content
- 4 replies
- 2,153 views
- 52 replies
- 11,727 views
- 0 replies
- 2,430 views
- 10 replies
- 4,197 views
- 0 replies
- 1,630 views
Gallery Images
