January/February 2010 ATV Photo Contest
quadcrazy
* We are extending January's contest into February for everyone dud to the fact that the community has been offline the last day of January through the first week of February, because of technical issues.
Theme: "Best Modified From Original" with your ATV, 3 wheeler, or UTV."
"Best Modified From Original" is basically anything that makes your machine different from factory (OEM) original. This could be addons, mechanical modifications, graphics, exterior accessories (luggage, winches, grips, ...), tires, etc...
Prize: UTVlifeSTYLE Magazinenew.gif & UTVOffroad Magazine (1 year subscriptions)
Rules: Submit your ""Best Modified From Original" with your ATV, 3 wheeler, or UTV." by entering it with a post, into this thread. (If you are not familiar with how to do this, visit the Learning Center) One photo per member allowed, so make sure it's a winner. You may submit photos that have not won past contests. Photos can be of yourself or taken by you. You may not submit photos that you do not have ownership of or permission to use. Any violation of these terms will result in disqualification.
Last day to enter a photo is February 24th.
Voting will take place for the last 4 days of February to determine the winner.
Voting will end February 28th and the winner will be announced!
Good Luck!
OK I'm in on this contest, not the best but I finally have a setup I like.
Trail: Mud Lite XTR 27x9-12 Front and 27x11-12 Rear / Mud: Highlifter Outlaws 29.5x12-12 Front and Rear
Sway Bar, Hockey Puck Mod, EBC Brakes and Rotors, 2" Snorkel, Black Magic Slip On, Exhaust Snorkel, Airdam Machined Primary, D Ring Tow Hook and Strap
Auto Meter Temp and Volt Gauge, All Balls Wheel Bearings and Tie Rods, 4" PIAA Lights, Super-Bright Red LED Taillight Bulb
F-1600: Tamarack Classic ATV Front Box w/ Speedrack Quick Release, Custom Graphics by Arctic FX, Hunter Green PowerMadd Star Series Handguards
Herculiner on Racks, Bumpers, Snorkels, and Box, Circuit Breaker for Fan and Main, Coolant Overflow Tank Vented Near Pod, One-way Valve on Carb Drain
60-IN. AC Plow Blade - Modified, Remote Angle Control, and Winter Front
I'm in. Here's mine:
LSR +3 LT A-Arms
Elka triple rate shocks
Blingstar Iron cross Bumper
Pro Taper Bars
ITP Rims
ITP XCT Tires
ODI Lock on Grips (love those things)
twin air filter
AC Nerfs
+3 rear axle
WB full Exhaust
HRC Cam kit
Pro Armor teather kill switch
Braided Brake Lines
13 tooth front
Twin Air Filter
and a bunch of other stuff that I can't remember at the moment
Edited by KFx400jim
Here is my '02 Honda Recon. I call it my "Budget" ATV since I'm trying to keep my mods cheap! I wish I could post two pictures to show you a before and after, but here is a pic of it today. I was wanting something mainly that I could take deer hunting and play around on. When I traded for it a month ago, it was bone stock, bald tires, "PINK" handlebar grips,:aargh: rusty racks, no brakes, etc. Since then, I've fixed the brakes, added a 2" lift, added 1.5" wheels spacers, painted all the racks, got some black handle bar grips, added a 2,000 lb winch, added a camo rear pack/padded seat, and 25" wheels and tires from a Honda Foreman. I was glad to find the wheels and tires locally for $125. They were like brand new and bigger than stock. I modified a snow plow I found laying around from a lawn mower to clean off my driveway. It's not fancy, but save my back from scooping snow! All in all, I have about $1,500 in it total. :biggrin:
98 Banshee
Coolhead w/ 20cc domes
Wiseco pistons
Vforce 3 reeds
Aggressive dune ported
CPI inframe drag pipes
Timing plate +4 degrees
Aluminum waterpump
Hinson clutch basket with hd springs (lockup in the future)
Modified shift star
Maier plastic, cut front and raptor style rear (soon to be cut)
+6 swinger
+4 axle
+2+1 arms
Stainless brake lines front and rear
Wave rotors front and rear
Pro taper bars
Duncan bumper
Trailtech lights (not on in this pic just got them on before our last dune trip)
21 inch 8pdl haulers and mowhawk fronts on douglas blue lables for the sand
18 rear and 19 front mx claws on douglas red lables for the dirt
lots of powdercoated and polished parts
Edited by jigolbeep
    • By Tuzz
    • By huntindog
      TIA
    • By 2wdrancher
      Hello everyone I have done a ton of research on doing this conversion because I hate getting stuck in the stupidest places and not being able to back out. I will be documenting my conversion here and on a couple other forums and probably post a couple videos on YouTube. So what I’ve come up with is all you need is a front axles, front propeller shaft, the final shaft inside the engine and the 4x4 front engine cover . I will list all the part numbers for everything that you need and prices from about six months ago (sorry) , you DONT need to switch out hubs, knuckles, or anything like that, and if you want differential lock lock like the foreman and Rubicon you can get a foreman Rubicon front differential and propeller shaft with the diff-lock and get a knight sure four manual actuator for it and voilà you have four-wheel-drive rancher. Input from you guys is greatly appreciated thank you for your time!
      Note: I would definitely get the aftermarket HD axles because they are definitely stronger and are around the same price as oem
      FINAL SHAFT
      23611-HR3-A40  =$80.48
      BEARING
      91006-HP5-601   =$11.11
      OIL SEAL
      91202-HR0-F01   =$ 7.94
      COVER ASSY., FR. CRANKCASE
      11300-HR3-WB0   =$206.99
      PROPELLER SH AFT
      40400-HR3-A20   =$91.50
      FINAL GEAR
      41400-HR3-W50   =$714.88
      FINAL CASE BRA CKET
      50350-HR3-A20  =$7.40
      FLANGE BOLT
      95701-08016-08  =$1.49
      R. SHAFT SET
      44250-HR3-WB1  =$240.64
      L. DRIVESHAFT
      44350-HR3-WB1  =$240.64
      This is all for the 2x4 - 4x4  lever that comes in stock on the ranchers. I would definitely recommend looking for parts for wheelers on marketplace,  or craigslist
      001
      NUT, ADJUSTING
      41560-HP5-600
      $6.51
      002
      CABLE, FR. FINAL CLUTCH
      41570-HR3-A21
      $6.56
      003
      SPRING, CLUTCH CABLE
      41571-HP5-600
      $1.95
      004
      CLIP, CLUTCH CABLE
      41573-HP5-600
      $3.23
      005
      GROMMET, CLUTCH CABLE
      41716-HP5-600
      $3.12
      006
      LEVER, FR. FINAL CLUTCH
      54030-HP5-600
      $8.91
      007
      PILLOW BALL, FR. FINAL CLUTCH
      54031-HP5-601
      $10.87
      008
      BRACKET, FR. FINAL CLUTCH
      54040-HP5-601
      $11.19
      009
      SPRING, FR. FINAL CLUTCH
      54041-HP5-600
      $1.86
      010
      GATE, FR. FINAL CLUTCH
      54050-HR3-A20
      $4.55
      011
      GRIP, FR. FINAL CLUTCH
      54321-HP5-600
      $8.95
      X2 012
      BOLT, FLANGE (6MM)
      90111-162-000
      $2.54
      013
      NUT, SELF-LOCK (6MM)
      90343-ZE6-000
      $1.70
      014
      JOINT B, BRAKE ARM
      95015-32001
      $0.82
      X3 015
      BOLT, FLANGE (6X12)
      95701-06012-00
      $1.34
      Or Forman 520 w diff lock
      FINAL GEAR
      41400-HR4-A21  =$732.49
      PROPELLER SHAFT
      40400-HR4-A20  = $92.54
      And you definitely need the sure four locker for this
    • By vlxerdon
      Don
    • By p5200
  • Similar Tagged Forum Content
