the real newbie
  • Admin locked this topic
    • By huntindog
      TIA
    • By vlxerdon
      Don
    • By Whiterabbit
      Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!!  I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
    • By 86ccord
      Just picked up a 2008 Big Bear 250. It was sitting for about 1 year it's definitely a project. Currently chasing down a no spark issue. Imagine that lol
      Tons of info around the forum. I look forward to learning!
    • By p5200
      I bought a seal driver kit but, the spring that goes around the lip of the seal came off inside the hub. I have another seal but, I wanted to check here first to see if maybe I should use some steel wool or something around the metal edges of the seal. I'm open to all suggestions. Thanks! 🙂
