This is a GREAT thread!!! Great idea, we have always wanted to know how everyone finds the site so that we can improve our online exposure! Hats Off! :wink:
Looking forward to everyone's replies!
I can't wait to tell little Jnewell that passed up riding 3 Can ams today. Some guy who was parked next to us at the trailhead had two 500's and a 800. All he did was complain about the 800 and how it couldn't climb slippery rocks. Too much power, he would just spin the tires on them. The same rocks that he cried about I flew up!
I Cant remember now,,,,Its been a few yrs.....You newer guys are lucky....This Site wasnt anything like this when I found it....It had just come out of the Womb:laugh:
Im glad everyone is Enjoying themselves...
I'm like you MWKE..I was here when this place was nothing like this. The forum was nothing like this at all...it has really come a long way!!!
I saw these from the early days (Banner at the bottom): Get Involved » QUADCRAZY ATV Community
trailblazer posted a myspace bulletin about this place so i gave it a shot. i like this better than atvfan as well :bannana_guitar: and because they have some cool smilies
Yep, the smileys rock! :cute:
I found this place by just doing a google search. My first post was to the contest section....then just started getting more into it as time passed. Told my Stoopidbot bout it, and, well, you all know where he's at on the site now! :biggrin:
YES I WIN!!!
hahahahaha
I enjoy this site way more than ATVFAN. Like Tri-Z said, much more relaxed
haha i like this better because everyone isnt can-am worshipers.
LMFAO
I just got through writing a post that might get me kicked off, i wrote a pretty hateful one toward Can-am and jnewell, but a guy named extman chimed in so i shut his as* down too, i feel banning coming if this keeps up:bouncing_smiles:
    • By Callaway
    • By McG75
    • By Johnnyhorsepower
      I finally found an awsome app for your phone that shows you on a map all the trails near your location. You can read or add reviews, look at picts...etc
      Its called: atv escape
      John
    • By Tjp5093
      I need help identifying where this little part came from in my 02 Honda forman case. It looks like it's steel and broke off of something. It was having shift issues. Not sure if it's related or not. I will pay whoever can tell me where it came from.$$$$$$$$$$$
    • By LT-4WDinNY
      I got the side cover off, learned how to put the subtransmission back together. I took the nut off the crank. Grabbed the new flywheel puller. Put the small piece on to protect the crank shaft end, and the flywheel fell off on its own??? So that was weird. I then looked and tested the starter one way clutch. It wasn't in pieces like I had seen on others on YouTube. It only turns in the one correct direction as indicated by the arrow. However, it looks like maybe it is slipping under load? Is that possible?
      I know that it was very difficult to pull start since I bought it back in 2001. The guy I bought from had the receipts on a recent engine rebuild by our local Suzuki dealer in the $1200 range because they put the oil filter in backwards. Anyhow, I am trying to make it easier for my kids to ride. I think I verified that the starter clutch was bad by removing the electric starter, then it would pull start normal...
      I took pictures of the one way clutch and the CALTRIC replacement parts I bought off Amazon. Looking closer, appears to be heavy wear on the metal pieces in the clutch and scratches on the starter gear surface that goes inside the clutch. I am going to replace the OEM parts with the CALTRIC brand parts off Amazon.
      However, I found some other discerning things behind the flywheel. Looks like the center case has cracks, and one broken off tab with the other 2 worn? Also it looks like some scraping inside the case bottom right... assume from when the post broke off.  The post was NOT in the case, so probably occurred prior to the Suzuki Dealer rebuild.  Also some discoloring on the crankshaft and back of starter clutch.  Again, putting in the CALTRIC brand replacements for the starter clutch and starter gear as a set.
      Thanks!
      Bruce
