I run a half pound less of what the rating is just for comfort. Takes a little bit of the rough ride out.
I also use nitrogen in instead of air.  Nitrogen has no pressure change through the seasons cold or hot so my tire psi always stays the same.
nice @Frank Angerano!  I just follow whats on the tire no questions asked lol
they can hold a lot of air though- not recommended, I picked up my sportsman from my friend and one day decided to check the pressure- supposed to be around 10 psi (these are kenda executioners) and he had pumped them the 40 psi in front and 50 rear- needles to say I immediately let the pressure out down to spec...
  • Haha 1
  • 3 months later...
It depends on the combined overall weight (Pilot + machine) and the terrain you plan to ride into if you are planning on a tarmac ride I'd rather use close to 14-15 psi
but if you intend to ride on mud,sand or snow I'd go to the 5 psi side of the spectrum .Low pressures increase grip, High pressures increase tire duration. Nice rides!!
3 minutes ago, Chris Stokes said:
What tire gauge are you guys using? My stick pressure gauges that I tend to use for truck tires is not very accurate at the pressures needed for atv tires (5-8psi) I am just curious what others are using and have had good luck with.
I typically use a regular tire gauge like this:
ATV Tire Guage
  • 4 months later...
On 1/30/2020 at 3:11 AM, quadnut20 said:
I have a low pressore gage I run about 4 lbs
I'm also using same gauge and it seems to pretty accurate 👍
  • 9 months later...
  • 5 months later...
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By HHurks
      Hi to all
Ă—
Ă—
