What internet browser do you use?
36 members have voted
  1. 1. What internet browser do you use?
    • Internet Explorer
      15
    • Firefox
      20
    • Safari
      1
    • Google Chrome
      9
    • Opera
      1
    • Other
      1
Internet Explorer (What version, 7,8,9)
Firefox (What version)
Google Chrome
Safari
Opera
Other
Just curious...I am using Google Chrome and notice that it is much, much faster.
Added a poll, you can chose more than one.
Edited by Ajmboy
I usually switch off between firefox and chrome, i normally use firefox but this last update made it really buggy and it seems to like to freeze a lot for no reason. So now im using the latest version of chrome.
  • 7 years later...
Chrome 95% of the time.  Fast, easy.
Will use MS Edge / IE if there is a issue with Chrome.  I've only really experienced issues with Chrome when using net based file servers, specifically utilizing files active by multiple simultaneous users.
Ironically, this post is coming in from Edge...….
4 hours ago, bimmer said:
firefox comes with ubuntu and leaves nothing to be desired.
Do you have a machine you are running Ubuntu on? Do you not use windows, mac or other system? Just curious, always thought of loading it on an old pc but never did.
As far as this thread, I mostly use Chrome on my desktop, laptop, tablet and iphone.
I've used them all in the past, but always end up back at ubuntu. It's just so easy, the latest version is no big deal to get, it'll run decent on even the most crusty machine, it's wonderful. Right now I'm on one of those really cheap throwaway computers that doesn't even have a hard drive, just 30gb soldered to the board. It wasn't capable of upgrading to the new release of windows ten, and was painfully slow anyway, but a fresh install of the latest ubuntu takes only 8gb and leaves me with a nice running, simple cheap laptop. If you don't do anything unique you don't have to do anything beyond what comes with it, there is loads of specific software for those that want it, mostly free, if you don't mind a small learning curve, give it a try.
  • Thanks 1
I may try this when I have time.
Anything but IE. Currently using Firefox and Opera. Had been using SeaMonkey for a long time. Must up-date it and get back to it. For you long ago NetScape users, SeaMonkey is your current replacement.
IE and Edge on my work laptop. Opera on my personal. I used Keyboard browser on my android BlackBerry but the developer stopped supporting. Now use Edge on the GooBerry
    • By Quadman11
      Hi Guys, First post.
      I'm Having an issue with my KLF300 2X4.
      Just purchased a 2000 model KLF300, when i first rode is i noticed the gear shifting from reverse to first and vice versa was extremely hard and stiff.
      Now When the bike is running it is Shifting straight past neutral into reverse without using reverse lever, making neutral impossible to find. Also the neutral light and revese light has stopped working. To get the bike started i grounded the green wire coming from the switch so now i can start it again but the shifting issue is still there.
      I have adjusted the reverse lever and cable so that it is fully retracting but this hasn't changed anything.
      Can anyone recommend anything to check etc?
      Thank you.
    • By Strike37G
      OK gang, first post so don't bust me up too bad. I am so out of my element here because I usually wrench Jeeps and an intermittent Charger.
      I am taking a 250cc Zongshen engine and grafting it into a 2002 Yamaha Blaster. After modding mounts, carb, intake etc. I have ran into the problem of the engine harness to wiring harness. Both have 5 wires for the mag but the colors don't match. anyone have any experience with bridging the gap between the two? The first picture also has a 6 pin connector that I have no idea about. The second and third pictures are the loose engine wires and wiring harness with the connector. The whole project is sitting at about 95% and I'm ready to finish it. Any input would be greatly appreciated!
    • By Arizona
      Trying to figure motor size, says nothing on plastics, or the title, only numbers are EC25PFX 01 Which
      are on the cylinder. The vin code is 4XAAG25C312459874
      Tried vin search but still doesn't show motor size.
    • By Arizona
      So few months ago I acquired a 01 Explorer 4x4 (think its a 350 but not sure)
      Anyway the owner said it started reving very high, shut the key off and still kept running
      until finally he shut off fuel and it finally died. During the run away he said the exhaust got
      red hot and has melted plastics to prove it. Said some thing flew out the tail pipe, I kinda figured
      it was the top of the piston. Anyway finally got around to looking at it (have a lot of other projects in the works)
      and checked the compression, Shows about 40 psi. Can hear air coming out the carb while rotating the motor over.
      Gonna pull it apart eventually, don't hear any noises or binding in the stroke, You think the piston came apart?
      any horror stories of these and is it worth my effort and money? Don't really have any money in it yet. Thoughts? Az
